Howdy Gentlemen and Gentleladies...
I've done a search and came up with donuts...
I believe my lifters are on their way oot, I have a particular bad 'tick' @ start-up, but once the oil get's a little warm it tends to go away...!? :confused:
Two questions: 1. Do you have any other alternate ideas of what this may be (as can't really be arsed changing lifters)
2. If not, then does anyone know where I might be able to purchase such a part?
Thank you people...
Edited by Savage Bliss
https://www.sau.com.au/forums/topic/107479-rb20-lifters-on-way-out/
Thank you people...
When was the last time you changed your oil filter?
I've normally always done a filter change after 10,000 kays (or 2 oil changes) but I noticed when my 33 was nearing the 10,000 mark on it's filter the lifters were tapping increasingly on start up, then would go away. After I changed the oil & filter the noise was gone & haven't had it since. I'm thinking of changing my filter every time I do an oil change now as I don't want to starve my turbo of lube either.
No wonder there are so many rooted Rb engines on this forum.
Turbo oil change is 5000K's or 6 months.
This practice of changing oil at 5000K's and doing the filter every 2nd oil change (10000K's) is absolute madness.
If you want to keep the engine at all healthy, do 2-filters to each oil change.
Filters are cheap as chips and why would anyone in their right mind pump new oil through a dirty filter.
I do my oil changes at 3000-5000 and filters at 2000max.
I know!! No need to make me feel like sh*t!! :D Oil does get changed on a regular basis, oil filter however I've seemed to neglect the past little while.... Cheers guys...
Well I'll be changing my filter every 5000 klicks with the oil myself, I don't really think there's any point in doing it more often than that. If a filter can't last as long as the regular factory service intervals there's something seriously wrong with your engine already. The majority of crap will build up in the latter half of the 5000 kays anyway when the oil starts to deteriorate.
No worries savage, glad to help.
Edited by Electro
If anything it should be the other way around.
Filter every 5000k oil at 10,000kays.
The oil will last the distance, the filter won't. :S
But do both every 5k. Use a decent mineral oil, there really is no need for a mild rb to run synth unless you really want to.
I run synth because I've thrown 6k at a motor :geek:
yes.. no need to go insane on them..
Add upper engine cleaner into a couple of oil changes, and see if it makes a difference..
Also, what sort of oil you got in there at the moment (do you know?) - maybe its simply a bad match for your particular engine/age.
I'd try these before going sick getting your head reco'ed, etc.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
