I know i know..........another thread about the pod vs Panel filter thread, but all the threads i read on this, the cars are only pushing 150 - 200 rwkw.
Say at 250rwkw would there be a restriction with airflow as opposed to a pod filter?
I have a POD atm but looking at putting the standard airbox in with the k&n to avoid an epa as i have a fmic also.
Anyone had a dyno run to see the differences at this power level?
thanks ...Jim
I've got the stock airbox/snorkel on my car. When the lid of the box was taken off it made an extra 5kw on the dyno. I've been trying to think of a way to make the snorkel / lid opening bigger because i want that extra 5kw ;) and i dont wana have to use a pod :)
thanks ...Jim
I would have thought that the restriction would be in the intake pipe from the box to the turbo and the intake pipe from the outside to the box.
fix those 2 up and I'd say the stock air box and k&n panel would be just as good if not better than pod.
On my 32.. I've modified it with an extra feed from below the airbox, in case it needs it.
I used a hole saw to cut out the circular section. Fed that with an old piece of intercooler piping, that goes to the front bar area. Invisible to the eye, but gives an extra feed to the box if the engine needs to suck in more (cold) air.
got any pics ??
just trying to understand wat u mean exactly.
i remember reading a thread about someone that actually put a pod filter in a standard airbox on an r33 (with pics)...and also had a cold air feed from the front of the airbox as preadator mentioned (had a look for the thread but no luck)
Edited by Jim
thanks ...Jim
You didn't read the threads very carefully because I know I have posted that I have 255rwkw with stock air box and panel filter. All indications are that it poses no restriction. Mik has something near 400rwkw in his GTR with stock air box.
I might pull the top off the box at the dyno day to test the restriction of the snorkle.
Well said Adam
I was just about to add that both Mik and Sewid are pushing over 340awkw and both using the factory airbox in an R33 and R34 GTR respectively.
i am surprised noone havs brought it up yet ... Mine's R34 ... stock aribox and wat 600hp or something like that? and the response in theat car apparently is awesome, so i dont believe the stock airbox would restrict it that much if you are worried about using the stock airbox maybe you could try an ARC ( if they make one for your make ) airbox they are apparently very good.
my 2c :O
YEP I'VE GOT 255RWKW ATM AND DID TAKE THE TOP OFF THE AIRBOX AND AIR FILTER OUT FOR A DYNO RUN AND ABSOLUTELY NO DIFFERENCE. FACTORY SNORKEL AND AIRBOX, K&N AIR FILTER. R33GTST.
PODS ARE FOR DEFECTS AND WHOOSHY SOUNDS - WE ALL LOVE WHOOSHY SOUNDS...
CHEERS
Edited by gtst25
Well I was going to start a thread as I was a bit suspect that a POD was worth shite apart from another $100 or so out my pocket & a lot of noise.
I've been thinking of going a Blitz dry type panel filter as the K&N oil filters will require you to clean your AFM on a regular basis (unless you go to an aftermarket ECU & replace it with a MAP sensor). Don't really want the extra hassle or risk of it running lean.
Well I've just ordered an Apexi air filter from Nengun along with a couple other bits to cheapen the freight. Should be interesting to see what kind of difference it makes. I won't be dyno'ing it for a while though
  • 1 year later...
Old thread.
But I have 247rwkw r33gtst. I have modified the snorkel so that it clears the FMIC that comes over the top. So I cut the snorkel and used some plastic to seal it up. Boost dropped to 0psi above 6000rpm.
I have now hacked the snorkel more (as no longer needs to clear stock intercooler pipe and used 1.5mm sheets of plastic to seal it. Holds a little better now but still poses a restriction above about 6300rpm.
With the snorkel removed runs to 7000rpm no troubles :ninja:
I still want to have some kind of air ducting to prevent hot air feeding the intake. Because of the stock airbox it's hard to bring the air feed from the existing hole where one of the stock intercooler pipe went through.
Anyone got any innovations here?
I have a pod in the garage but I would rather keep it looking as stock as possible while keeping inlet charge cool.
Edited by benl1981
I have 260 rwkw's on a dynolog and snorkel on/off only 1 odd kw difference ....... WITH BONNET UP....... also boost held up well , only dropping 1psi 18-17
However on street with bonnet down i was flat out getting to 16 and dropped to 12........ But bonnet rubbers were worn and bonnet was about 5mm below guard level..... so i bolstered it up to 5mm above temporarily (only over a year now haha) and it was alot better...... yet to try difference on dyno with it down..
About to retune with new turbo and auto so i'll try it out then, as i too am going to do an extra breathing mod that looks good/factory/stealth etc .....
