Interesting mate,
I just had a look at my car and it looks like the bonnet is sunken down by a few mm also.
Could be a contributor. I'm going to try to get a second air feed to the bottom of the snorkel and maybe raise up the bonnet a little.
So you are running with the snorkel and bonnet raised slightly?
Cheers
  benl1981 said:
Old thread.
But I have 247rwkw r33gtst. I have modified the snorkel so that it clears the FMIC that comes over the top. So I cut the snorkel and used some plastic to seal it up. Boost dropped to 0psi above 6000rpm.
I have now hacked the snorkel more (as no longer needs to clear stock intercooler pipe and used 1.5mm sheets of plastic to seal it. Holds a little better now but still poses a restriction above about 6300rpm.
With the snorkel removed runs to 7000rpm no troubles :)
I still want to have some kind of air ducting to prevent hot air feeding the intake. Because of the stock airbox it's hard to bring the air feed from the existing hole where one of the stock intercooler pipe went through.
Anyone got any innovations here?
I have a pod in the garage but I would rather keep it looking as stock as possible while keeping inlet charge cool.
Had the same problem. Fixed it up by cutting a hole on the air box lid. But the real problem was the rubber pipe from airbox to turbo was sucking itself shut beacuse the snorkel was sealing up against the bonnet. A more solid pipe would be the go but the extra hole worked fine.
  benl1981 said:
Interesting mate,
Cheers
Yes, running as stock, on outside, just with an apexi panel filter fitted. (Nice dry type not oiled!) factory snorkel etc .... just bonnet popped up on pass side 5mm odd. Oh and as someone mentioned above you do have to make a new intake to the turbo from the box, as stock one will cave in on itself
Have ran a 12.3@ 113mph , 1.9 60' . like this and it was far from being a perfect run Car is Auto sedan too.
So maybe you should just try putting some rubber temporarily over the stock bonnet rubber for a try first,? especially if you have less or similar power levels.
Ps , Dont forget to zip tie down the scoop if you dont have the factory bungs in place, as it might suck itself up to the bonnet ! (i can do a pic if you don't know what im getting at here)
Gary
Edited by Fastrotor
  • 4 weeks later...
  • 3 weeks later...
  Johnny said:
ive got this nismo snokel in my r34 gtr, i think its made of kevlar and might be a good option for those who wanna keep their stock airbox and want a less restrictive snorkel.
Yeah i was looking at adapting the r33 GTR snorkel onto the gtst box as its bigger..... would be nice if there was an off the shelf one available though... something to retain a factory look.
Gary
Oh by the way .. probably should start a new thread to help those searching ..... but on the subject of bonnett support rubbers, the ones that screw into the front radiator support, i just tried a N15 pulsar ones tonight and they fit perfect.... so probably easier asking nissan for one of those then chasing an import number, assuming they wern't already clued up.
Gary
Edited by Fastrotor
Or go to the wreckers and save some $$$ :P
Mine was just tuned last night. Stock airbox, Blitz FMIC, full exhaust, HKS GTRS, PFC, 256rwkw on just 16.5 PSI. There was another 3rwkw when using the top half of an airbox that had holes cut in it. Bonnet up I assume (wasn't there for the tuning). Graph in turbo upgrade thread soon.
Edited by sl33py
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 馃槩, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 馃
