Does anyone know much about this engine, or has used it.
Im actually quite interested, but seem to be VERY unable to find any specs on it.
For anyone that knows a bit more, Id like to ask the following questions.
#1 It comes with a tomei oil pump - is this the standard spec model which is worth $1500
#2 Whats the recommended rev limit on this engine
#3 Can you order different camshafts with the engine, rather than the standard poncams?
#4 Does it come with a tomei larger sump or not ?
#5 Whats the static comp on the engine?
#6 What recommended maximum boost can be run on the motor?
#7 Does it have a standard block or an N1
#8 Is the motor custom made for either 32, 33 or 34 gtr, or are they all the same. Will all these parts bolt onto the engine off a r34 gtr ?
Thanks to anyone who can help
linky here
https://www.sau.com.au/forums/topic/107482-tomei-rb28-limited-genesis/
  • Replies 140
Posted Images
Guest Mashrock
http://www.tomei-p.co.jp/_2003web-catalogu...ete-engine.html
read through there.
and then
http://www.tomei-p.co.jp/_2003web-catalogu...4_rb26dett.html
from what i remember you have to supply an engine.
and i will add this one too..
http://www.tomei-p.co.jp/_2003web-catalogu...g-kit_rset.html
Edited by Mashrock
I have investigated alot of the complete engine scenarios, as ive been thinking about putting one in my gtst instead of buying a gtr
I have a re-fresh book (all in japanese) about the rb26dett with full color and alot of pages, there is a big section on tomei and their complete engines. Ill bring it here and put some info up next time im on the net
Your looking at 25-30K
Mines complete is a bit more
But add up the cost of getting a GOOD engine rebuilder to make you an rb28 with full hks 2.8l kit and n1 block etc
Hey guys, thanks for that.
I've found a bit more info out from one of the aussie distributors.
Engine cost is 2,020,000 for the complete engine. Exchange price is about 1.7M, but obviously im not shipping an engine back there.
It does come with the Tomei sump and oil pump (which are worth a good 300,000 yen (exchange for the sump). You can order the HG thickness, and the camshaft sizes.
Rev limit is approx 8.5k, (unless you get a damper i think)
Not sure if it is a 32, 33 or 34 motor, because normally when you exchagne, they rebuild your motor.
Also, the guy didnt answer me as to whether it runs a standard N1 block or a standard nissan block.
knore - That book would be excellent, provided it details the genesis limited 2.8 litre tomei engine. Apparently there have only been about 15-20 manufactured. There are only 3 of these motors (apparently) in australia.
Pricing a good engine builder to build a full 2.8 with completely new internals, ported head, etc etc, and you're looking at a good 25-30k
Which is not any more than this custom motor. I assume tomei would know how to build a decent motor ?
I agree a Tomei engine would be a dream for me,but $25000 seems excessive.If they rebuild your motor they obviously dont use an N1 block.I can get their 2.8 stroker kit for $5950,oil pump for $1300.If you allow around $3000 for an N1 block,$3000 for the head work,it allows alot of room for extra costs,plus the cost of shipping an RB26 back to Japan.You also have to allow for the price of the RB26,maybe $4000.
Warranty issues could be a concern with them being so far away.
Still it would be really nice having one....if you can afford it,go for it.
Guys
work out the cost before you talk
Ive looked at the cost of all the parts that are in the engine
For example
Capacity : 2770cc
Max Power : 580ps/7500rpm (DERIVE)
Max Torque : 60kgm/6000rpm (DERIVE)
Boost : 1.3kg/cm2 (DERIVE)
(DERIVE/GENESIS)
Piston : TOMEI 87.0mm
Conrod : TOMEI H-shaped
- 620000 Crankshaft : TOMEI 8 counter weights type
43428 Titanium Piston ring Set
- Oil Jet Spacer : TOMEI
31416x2 Camshaft : TOMEI PONCAM
32456 Head Gasket : TOMEI
36152 Valve Spring : TOMEI A-type
~44352 Valve Guide : TOMEI PBB
20328 Main Bearing : NISMO
15708 Rod Bearing : TOMEI
11088 Rod Bolts
-Head Bolt Washer : TOMEI
-Oil Gallery Orifice : TOMEI
15477 Timing Belt : TOMEI
-Throttle Gasket : TOMEI
-Manifold Gasket : TOMEI
138600 Oil Pan : TOMEI
18295 Oil Pan Baffle Plate : TOMEI
1800 Oil Filter : NISSAN
127512 Oil Pump : TOMEI
~30000 Water Pimp : NISSAN N1
6468 Thermostat : NISMO
8000 Spark Plug : DENSO Iridium
-Color : Powder Coat Painting
-Plug Cover Ornament : TOMEI
-Oil Filler Cap : TOMEI RB26 Piston type
Total cost is around 1,232,496 yen from greenline (plus shipping).
Now you need to build it all. Port the head to fit the bigger cams, add guides, springs, etc. How much labour are we looking at for the head
Bottom end needs machining, and then assembly later on. How much would it cost for all this.
Then thirdly, what sort of quality would you get ?
Okay, given a 5k bill on labour, would raise the total cost of the complete engine to $19500.
Considering this engine costs 2M yen = $23.5k, plus shipping (ignore duty).
AND the fact that a 34 long motor will fetch around the 4-5k mark, means you get tomei build quality for much the same money ;)
This is how I have justified it to myself. Does anyone see any flaws in my theory ?
Guys
For example
Capacity : 2770cc
(DERIVE/GENESIS)
11088 Rod Bolts
sounds about right to me, and the stroker kits are damn pricey when buying everything seperate, and mine with the jun crank rods and pistons is about 12k by the time its delivered, and then u got cams, valve springs, retainers, headwork, cam gears, bearings, sump, gaskets, etc etc, which u wont get a cent of change from 25k by the end i reckon with all the little bits and pieces u dont usually even consider in the final price.
i say 23k is a bargain, and most builders in oz who are half decent will have 6 month waiting lists anyway so its possibly a quicker/simplier/easier option over all.
go for it i reckon.
cheers
Brad
If your willing to go to that far building your engine,then with the sums you've done,its probably worth it.
It's just that you could build a trouble free 600hp RB28 for alot less in Australia.
Let us know how you go,could be a very interesting car when finished.
Just calculated that 2,415,000 yen is $28,000+.
Do you still have to provide a replacement motor.
You also make no mention of what block they use.
HAHAH YOU GUYS ARE f**kED. Mate has RB30/25 running with an 10k bottom end. I thought that was out of this world. ASIF SPED 20k. Use RB30 bottom end, rb25 or 26 top, massive cams get out of it aroubd 15k all up and im sure you will be runing same if not more power, more responsive and have a whole bag of money in ya pocket to buy a really good ECU and even a set of NEW RIMS :DDDLD::P:DD:D Tomei = waste of $$$ Racepace is your friend!
You want me to run an rb30 out of a commodore as my bottom end ?
I do want an engine that can rev. Rev limit on these engines is, SAFELY 8500rpm. I dont like the response of rb25's, and i assume rb30's will be no different.
So what if i save 4.5k and am unhappy with my r34 gtr with a slow revving old arsed rb30 engine :P
Guest Mashrock
i can definatley see where your comming from.
i was going to get my gti-r done when it was time for a rebuild. but ended up going local..
i didnt really read your questions haha, but as i think you've found out they like you to supply a block.
i'd say go for it. the parts alone are worth a fair bit..
decent head work costs a pretty penny over here!
and then the build and etc..
and you know your going to get quality from tomei..
find out about the shipping tho and then dities etc. and see if it adds up
Once its done, I want to race you with my "slow revving old arsed rb30 engine"
and I'm sure your comeback will be ok at the track which Im sure Sydneykid can supply you with another slow revving old arsed rb30 engine powered car there aswell
please think before you type stuff like that as just because its not right for your car doesn't mean others don't like it
why lower yourself to someone elses level with a reply like that?
HAHAH YOU GUYS ARE f**kED. Mate has RB30/25 running with an 10k bottom end. I thought that was out of this world. ASIF SPED 20k. Use RB30 bottom end, rb25 or 26 top, massive cams get out of it aroubd 15k all up and im sure you will be runing same if not more power, more responsive and have a whole bag of money in ya pocket to buy a really good ECU and even a set of NEW RIMS :DDDLD::woot::DD:D Tomei = waste of $$$ Racepace is your friend!
I no speak-a de engrish...
why bother with rb30 bottom end... i know this guy who owns a 33 gtr in brissy cleveland area .. his spent a fortune on rb30 bottom end and 26 top n1 turbos etc.. doesnt make much more then 321kw @ all 4 wheels .. mind u his internals are all rebuilt forgies etc.. 260 cams the lot.. @ 321kw @ all 4 wheels he did blow his engine up.. only running 1.2bar.. i think japenese do know how to build engines.. same theory with 1JZ top and 2jz bottom end its all just trial and error.. if u got the money go for the tomei engine.. i think im lucky mine already came with hks bottom end :woot:
Sorry to offend you Brett,
Point is, Im after a stroker kit (or engine) for the 34. Im not after a hybrid rb30/26.
I have nothing against the rb30's, but i dont believe they suit my purpose.
While my reply seems "childish" you may have noted that i was replying to "ASIF SPED 20k", so I thought I would drop my level of simplicity (in terms of public speaking) down a notch or ten. You know well this is not an attack on you or any of the other rb30/26 hybrids (maybe just a shit stir).
At the end of the day, my reason for doing something like this is to have a car that will last. I want an engine built by a professional engine builder, and can justify spending 20k on the motor.
Out of curiosity, what do the rb30/26's rev to ?
:woot:
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
