I was actually thinking about that too. A sard rail (like the one you have) doesnt seem terribly expensive, and probably a good idea ?
yer they are about $400 i think for the sard one, and then u will need a fuel reg as well, around another $300ish i think (rough prices). dont wanna starve a 25k crate motor anytime soon :cool:
sump is also stock, worth an upgrade for sure.
  • Replies 140
Posted Images
Well, from what I can make out the Genesis doesn't come with any fuel rail at all; those ancilliaries are up to the end user to choose (the pictured engine a few posts ago is the Derive). Also the sump, whilst the OEM item, runs the Tomei baffle plates. See here*
http://www.tomei-p.co.jp/_2003web-catalogu...4_rb26dett.html
* Note that its for the 2.6l variety of engines
  • 3 months later...
Nah it wont be coming over anymore. TommyK has gone all old and boring, he has bought a house and is right at this second (im on the phone to him) is at the auctions looking to buy a falcon on gas.. auto.
  • 1 year later...
Probably just reiterating what every one else said but just had a 2.8 stroker built using an new N1 block ( fully prepped) using all the same parts as a tomei derive 2.8 with 270/10.8 pro cams and ati pulley
Trust T517z 8.0cm dumps .Have only just run it in so will be interesting to see how it goes at 1.5bar.
What I am saying is you would be better off getting it built here - Quality is second to none. Better off for comeback also!
Bit hard if you had a problem but Tomei engines are also high end stuff - also if you add some optional extras like mine it would cost a lot more for the same thing from Japan .
Lots of good engine builders in Australia - its not rocket science.
Thats my 2c
Cheers
Edited by ike
Thats my 2c
Cheers
Hi
any more pictures for the engine and car?
where did you get all the job done?
Hi
GTAuto Garage in Brisbane did all the modifications to a very high professional standard.
Highly recommend them to anyone thats requires top notch work.
Would now not ever go anywhere else.
Alex,Dave,Dave and Tim are great guys to do business with.
  • 2 years later...
Bringing back a very dead topic here, but as Tomei have the series 2 Genesis engine out now has anyone bought one or had any experiences with one? Basically they are more revised now and include virtually everything for a bolt in application, sump and all! RRP is $37,000 but RHD Japan have them for $19,500 delivered. I added up the cost of buying the individual parts included and came up with over $20,000 not including ANY labour for assembly.
Have you worked out the difference between the Series 1 and 2? There was a thread in GTROC and one of the photo's had a Tomei 2.8 photo. From what I can gather the difference is the crank.... I dont know what the differencees are. I have a Series 1 Tomei motor in mine and no problems.
Differences are:
conrods
crank
camshafts,
L19 rod bolts
Tomei head bolts/washers
Tomei main cap bolts
Tomei oil gallery orifice
Tomei timing belt
Tomei oversized oil pan with baffle
Tomei oversized oil pump
comes with spark plugs and Nismo thermostat.
So there are quite a few differences between the two, virtually every fastener is an upgraded item.
Yep Australian dollars. I think there might be a Tax or Tariff on it too, but i have bought goods to the value of $4000 from Japan and never got any extra taxed amount on it like your "supposed " to on any item/s over $1000.
see here http://www.rhdjapan.com/tomei-genesis-phas...nr34-gt-r-55011
^ aren't you lucky. Does not mean you'll be lucky again.
Especially considering it's not exactly small :(
It does not say specically that it is free to Australia - it says to check first.
Have you checked?
Also something else to think about, i remember a thread here or on another forum about a OS 3ltr that was purchased.
It was pulled down over here and found to be rather "average" in its assembly. So it was basically stripped and reassembled/rebuilt once it got over here.
Something else to think about.
I have a customer with a short on the way to his engine builder, should be real interesting. He went a bit crazy, Greddy T88GK, APEXI V-max spl (10000rpm kit) head kit (290degree 11.5 lift) full cnc porting etc... i cant wait to tune it ;)
Especially considering it's not exactly small ;)
Have you checked?
Im not trying to say i will get away with no tax, i havn't had much experience with buying from overseas, so i was more enquiring to anyone who has.
It wouldn't surprise me that the OS kit was second rate, it looks it just to look at! But to assume a Tomei engine could be the same is silly. They have a reputation much like Cosworth with their engines, so if one were to fail prematurely it wouldn't go down well.
I do believe that even for $25,000 the Tomei engine is a good deal. I havn't seen any other "turnkey" engine that looks as good (to me) for similar price. If you had an engine built with same quality parts i'd bet it will cost over 25g. I stopped building a WRX engine when it was getting towards the $20,000 mark...
OS is a "lesser" company and/or quality than Tomei?
Rightyo :down:
Either way, i'd be budgeting to have it pulled down and checked regardless.
I agree with ash here. For the money you have spent, whats a little more to get everything checked.
I wish I had done it when my supposed BIG engine arrived here (albeit already in the car)
I think Dirt had a new Tomei 2.8ltr crank that he had to re-balance recently as it was all wrong.
May want to shoot him a PM to confirm
So if i buy a motor from Lewis engines or Godzilla motorsports i should get it pulled down and checked if it was done correctly.. Im sorry i have never heard anything so ridiculous! Most engine failures are caused by bad tunes not bad engineering.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
