I was actually thinking about that too. A sard rail (like the one you have) doesnt seem terribly expensive, and probably a good idea ?
yer they are about $400 i think for the sard one, and then u will need a fuel reg as well, around another $300ish i think (rough prices). dont wanna starve a 25k crate motor anytime soon :cool:
sump is also stock, worth an upgrade for sure.
  • Replies 140
Posted Images
Well, from what I can make out the Genesis doesn't come with any fuel rail at all; those ancilliaries are up to the end user to choose (the pictured engine a few posts ago is the Derive). Also the sump, whilst the OEM item, runs the Tomei baffle plates. See here*
http://www.tomei-p.co.jp/_2003web-catalogu...4_rb26dett.html
* Note that its for the 2.6l variety of engines
  • 3 months later...
Nah it wont be coming over anymore. TommyK has gone all old and boring, he has bought a house and is right at this second (im on the phone to him) is at the auctions looking to buy a falcon on gas.. auto.
  • 1 year later...
Probably just reiterating what every one else said but just had a 2.8 stroker built using an new N1 block ( fully prepped) using all the same parts as a tomei derive 2.8 with 270/10.8 pro cams and ati pulley
Trust T517z 8.0cm dumps .Have only just run it in so will be interesting to see how it goes at 1.5bar.
What I am saying is you would be better off getting it built here - Quality is second to none. Better off for comeback also!
Bit hard if you had a problem but Tomei engines are also high end stuff - also if you add some optional extras like mine it would cost a lot more for the same thing from Japan .
Lots of good engine builders in Australia - its not rocket science.
Thats my 2c
Cheers
Edited by ike
Thats my 2c
Cheers
Hi
any more pictures for the engine and car?
where did you get all the job done?
Hi
GTAuto Garage in Brisbane did all the modifications to a very high professional standard.
Highly recommend them to anyone thats requires top notch work.
Would now not ever go anywhere else.
Alex,Dave,Dave and Tim are great guys to do business with.
  • 2 years later...
Bringing back a very dead topic here, but as Tomei have the series 2 Genesis engine out now has anyone bought one or had any experiences with one? Basically they are more revised now and include virtually everything for a bolt in application, sump and all! RRP is $37,000 but RHD Japan have them for $19,500 delivered. I added up the cost of buying the individual parts included and came up with over $20,000 not including ANY labour for assembly.
Have you worked out the difference between the Series 1 and 2? There was a thread in GTROC and one of the photo's had a Tomei 2.8 photo. From what I can gather the difference is the crank.... I dont know what the differencees are. I have a Series 1 Tomei motor in mine and no problems.
Differences are:
conrods
crank
camshafts,
L19 rod bolts
Tomei head bolts/washers
Tomei main cap bolts
Tomei oil gallery orifice
Tomei timing belt
Tomei oversized oil pan with baffle
Tomei oversized oil pump
comes with spark plugs and Nismo thermostat.
So there are quite a few differences between the two, virtually every fastener is an upgraded item.
Yep Australian dollars. I think there might be a Tax or Tariff on it too, but i have bought goods to the value of $4000 from Japan and never got any extra taxed amount on it like your "supposed " to on any item/s over $1000.
see here http://www.rhdjapan.com/tomei-genesis-phas...nr34-gt-r-55011
^ aren't you lucky. Does not mean you'll be lucky again.
Especially considering it's not exactly small :(
It does not say specically that it is free to Australia - it says to check first.
Have you checked?
Also something else to think about, i remember a thread here or on another forum about a OS 3ltr that was purchased.
It was pulled down over here and found to be rather "average" in its assembly. So it was basically stripped and reassembled/rebuilt once it got over here.
Something else to think about.
I have a customer with a short on the way to his engine builder, should be real interesting. He went a bit crazy, Greddy T88GK, APEXI V-max spl (10000rpm kit) head kit (290degree 11.5 lift) full cnc porting etc... i cant wait to tune it ;)
Especially considering it's not exactly small ;)
Have you checked?
Im not trying to say i will get away with no tax, i havn't had much experience with buying from overseas, so i was more enquiring to anyone who has.
It wouldn't surprise me that the OS kit was second rate, it looks it just to look at! But to assume a Tomei engine could be the same is silly. They have a reputation much like Cosworth with their engines, so if one were to fail prematurely it wouldn't go down well.
I do believe that even for $25,000 the Tomei engine is a good deal. I havn't seen any other "turnkey" engine that looks as good (to me) for similar price. If you had an engine built with same quality parts i'd bet it will cost over 25g. I stopped building a WRX engine when it was getting towards the $20,000 mark...
OS is a "lesser" company and/or quality than Tomei?
Rightyo :down:
Either way, i'd be budgeting to have it pulled down and checked regardless.
I agree with ash here. For the money you have spent, whats a little more to get everything checked.
I wish I had done it when my supposed BIG engine arrived here (albeit already in the car)
I think Dirt had a new Tomei 2.8ltr crank that he had to re-balance recently as it was all wrong.
May want to shoot him a PM to confirm
So if i buy a motor from Lewis engines or Godzilla motorsports i should get it pulled down and checked if it was done correctly.. Im sorry i have never heard anything so ridiculous! Most engine failures are caused by bad tunes not bad engineering.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
