kinda off topic, but what I'd really like to see (well more so HEAR) is an RB31 hi compression in NA form using the 6 throttles with trumpets on them, with a hi flowing exhaust.
sure might not make the power of the turbo ones, but it would sound awesome.
even more off topic, anyone got that video clip of the original race GTR which they pulled out for a few laps of some jap circuit that was being renovated or something..
awesom sound...
As for talk about RB30s beign truck engines, its kinda funny. You look at M3s, some of the greatest 6 cylinder engiens gettign aroubnd, you read the reviews of its revvy nature etc...yet ppl seem to think dynamically the RB30 cant rev ????
yes but spend m3 engine $ on an rb30 and the rpm outcome might be impressive. not the same of course because bmw are vv smart, but impressive nonetheless.
Sorry, I wasn’t being very clear with my post. Basically the RB30 has an 86 x 86 bore and stroke. And people say that the long stroke etc amongst other things means it wont rev hard. But you look at the latest M# which is generally considered to be a banshee and revs happily and it has an 87mm bore and 91mm stroke. So it actually has a longer stroke then the RB30 which invariably means higher piston speeds etc etc.
So dynamically there is no reason why an RB30 cant rev hard. Ok, fair enough cams may hurt power up top unless something has been done in this area, but if the rods a re good quality and balanced well,, ditto the pistons, especially with a turbo on the side of the thing it should happily pull good revs.
This talk of balancing etc.. I hear that some guys here are using old 270 000km bottom ends..doesn't sound like they care too much about balancing.
For a street car looking at 240-260rwkw - would you just buy a RB30 bottom end - if the pistons look ok just put new rings on and new big end bearings? Rehone it..
Would you really need to balance? Only plan to rev it to 6500rpm
Just going to be putting a lot of kays up on the car for new job so thinking of building a spare bottom end for if and when it needs a freshen up..
Also what turbo - GCG standard highflow...Would this not choke it up high..?
Sorry to deviate a bit.
yeah i think the hiflow is too small for the rb30det
i think the gt30 is the smallest you can run that wont run out of puff
and even that is still a bit too small, i think the gt30r or gt35r is spot on
would you just use the RB25 to make that kind of power rather than go to all the hassles of building the rb30 and swapping the engine, blue slip with new engine etc?
easy make 260-270 rwkw with std rb25..
personal choice for sure. then again, you might be in an r32 for all i know lol so then i would do it :whoops:
An RB30 with 260rwkw makes alot more torque than a RB25 with 260rwkw, some people swap to the RB30 because of the better drivability, and lots of extra torque.
fair call!
anyone noticed any increase i fuel consumption with the lower powered (220rwkw etc) RB30's V's RB20 or RB25's?
Well I'm also considering the cheaper option...It's only if my motor bombs out..
If I have a 3L bottom end with a freshen up there it is cheaper than an imported RB25 engine.
Anyone have any comments on my questions above? Maybe I should make a new post or something..
fair call!
Im getting around 10L/100Km atm out of an untuned pfc.
I cant run it up on boost, due to the coil packs wont take it (break down and piung like a bitch)
Its makes hella fuel economy as everyday driving is under 3500 rpm.
hmm thats what i used to get out of the std RB25.. will have to see. looks like there isn't much difference between the rb30 vs rb25 etc..
get a nice tune and that should improve i'd be thinking!
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
