I have just put a new motor in my r33 (rb25det). It is obvious that it has an exhaust leak off the turbo to the exhaust.
What is the best way to fix this as my car wont boost up, and it is pretty much undrivable how it is.
I had a quote of someone to fix it for $550. This seems a bit rich to me as it cant be that involved to fix myself.
Anyone else had this drama? can you please help me?
https://www.sau.com.au/forums/topic/107535-please-help-exhaust-leak/
do you mean manifold to turbo or turbo to exhaust? I am assuming manifold to turbo from your description.
Not a difficult job, obviously requires the removal of the turbo to replace the gasket. You can also do the turbo to dump gasket at the same time.
Both gaskets will cost you under $50. You are paying for labour as it is a 2-4 hour job depending on familiarity.
my gaskets on my GTR i think r failing. little bit noisey just after dumps..
some gasket sealant would do nicely
Gasket sealant might be OK for your situation (certainly not the OP's though), but its still not advisable. The dump --> front pipe gaskets are gettable without drama, so I'd just replace them with a new set personally.
As for the original question, lots of people have gaskets blow. With that much heat and pressure, and the constant expansion and contraction, its of little suprise really. You might have a broken stud as well, though the most common studs to fail and the head --> manifold studs. Speaking of which, its a good idea to replace those studs while you're at it. You may need to have a surface or two machined, and you'll also need a few incidental parts like locking tabs, etc.
yep correct thats the section of the exhaust im having dramas with.
Ive heard people say that the bolts used are aluminium and they are fairly common to stretch, warp or crack.
Is the a job I could tackle myself?
Could you explain to me what to do please?
Last time i checked, i think its 4 x 10mm studs from the manifold which the turbo bolts upto and that has a pressed tin gasket which i have never seen leak yet, infact ive reused mine twice now with two diff turbos. But you will need a screw driver to bend the locking tabs back and then a 14mm ring/open ended spanner to undo the four nuts. Will make it easier if you drop the exhaust, oil and water lines and prob intake side too which will let the turbo fall off and you can get to the manifold to turbo gasket. The heat shield is a bitch with like 10 little m6 bolts everywhere which is a 10mm spanner if yours isnt already removed.
Ive noticed that alot of manifold studs break generally always at the front and rear without alot of people even realising it. Its a common occurance so be weary you dont lose too many, cause it will eventually break through the gasket and start chuffing.
good luck if its your first attempt.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
