What is PSI??
The other guys have most of it right.
Yes it does mean pounds per square inch, this was the old imperial measurement for pressure. Bar has been since we moved over to metric. Americans still use imperial mesurements on somethings, and so psi is still commonly used.
Pressure is a measure of force over area.
Most engines will run at a vacuum while idling, an NA engine will go to 0psi at full throttle, a turbo engine will create a positive pressure over and above atmospheric pressure.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-174371
Actually I think atmospheric pressure is 1 bar or about 14psi?
That is the amount of all air above us pressing down on all objects on earth (air has mass and weight as any other materials). This is accepted as the standard pressure. We don't feel the air pressing against our skin or eyes coz our body is designed to adapt to it thru our evolution. Otherwise we'll all b crushed to death by now.
So actually NA engine actually runs the same pressure as the atmosphere at full throttle. Turbo engine runs more than the atmospheric level, depending on boost controller.
However to make things easier, the atmospheric pressure is set as 0 psi on boost gauges. So if your factory boost gauges shows 7 psi, that means the air pressure going into the engine is the 7 psi above atmospheric pressure... you are running positive pressure....
Sounds confusing, I read that thing from howstuffworks.com, however to avoid further confusion, let's accept that NA engine runs 0 psi (on boost gauge) on full throtle, and factory R33 boost is around +6-7 psi on the boost gauge.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175294
psi, psia, psid, psig
traditional symbols for pressure units used in hydraulics and plumbing. psi is a symbol for pound per square inch (see above). psig is a symbol for pound per square inch gauge; this means that the pressure has been read from a gauge which actually measures the difference between the pressure of the fluid and the pressure of the atmosphere. psia means pound per square inch absolute, which is the total pressure including the pressure of the atmosphere. psid, pound per square inch differential, is a symbol for a difference between two pressures, neither of which is atmospheric pressure. Corresponding symbols for pound per square foot (psf, etc.) are also used.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175315
OH and while I am at it
PS = pferdestärke
German word for horsepower, meaning the metric horsepower. The symbol ps is used for horsepower in both the Japanese and German automotive industies.
HP = Horse power (Metric Horse power)
a unit of power, defined to be the power required to raise a mass of 75 kilograms at a velocity of 1 meter per second. This is approximately 735.499 watts or 0.986 32 horsepower. The unit is also known by its French name cheval vapeur or its German name pferdestärke.
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-175319
The japanese like to use PS as their measurement for horsepower! Conversion is 1 horsepower = 1.01387 PS
Brake horsepower (bhp), sometimes called shaft horsepower, is the amount of power available for useful work. Bhp is less than flywheel hp because of the various power losses which occur during engine operation.
To determine the brake or shaft horsepower that is delivered as useful work by an engine, the sum total of all mechanical losses must be deducted from the total HP (initial or flywheel horsepower). BHP is the reading that dyno's use! This is also sometimes called RWHP or Rear Wheel Horsepower!
Here is an online conveter so if you know your HP and want to find out the PS/KW
http://locost7.info/converter.php
MEGA
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177053
rs73,
Your right that atmo is about 1 bar, that's why I said that turbo engines read over and above atmospheric, while NA reads 0psi relative to atmo.
So we are in fact using psig, relative to gauge pressure, that is we take all measurement relative to 1atm.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10755-what-is-psi/#findComment-177065
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
