Hello people, I’m a forum newbie and also a fresh skyline owner.
I have a few problems that I need to get fixed with my steering that I don’t trust doing myself, so I’m after a good mechanic? (I don’t have all the money in the world though willing to pay good if the quality is there)
I live on Brisbane Southside and own a 1988 Nissan Skyline R31 GXE, I’ve noticed that the steering is a little heavy along with some actionable pull to the left or right while driving straight. I suspect there is a some play in the joints around the wheel and also hear a clunk (Some where around the lower mounting of the front left shock) when hitting speed bumps.
Any Suggestions or recommendations with be muchly appreciated!?
https://www.sau.com.au/forums/topic/107550-after-a-southside-steering-mechanic/
My Dad is a mechanic with about 30 years experience, and has a home-based workshop, and he's a wheels/tyres/suspension expert. He did heaps of work on my R33 so isn't afraid of newer stuff either, and is about as honest/ethical as you're likely to find :whoops:
Cosmos Mechanical
(07) 3281 6575
Mention Skylines Australia and that Marc sent you :)
Related note: Skylines Australia Qld has sponsors including workshops, a tyre store, brake specialists etc, and conducts events that will allow you to enjoy your car to its potential. Details in the Queensland subforum on these boards :(
/shameless plug
We are not allowed to say bad things about workshops for fear of banning so I won't say this.....but whatever you do, don't take your car to Charlies! There you go, you've been warned.
Marc's dad sounds like the way to go. Marc is an honest bloke so I would assume his dad is twice as honest at least.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
