Evening,
I've had my car for just on 4500k's now and I'm gearing up for my first service, I'll be doing box, diff and coolant as well as oil, oil filter, clean POD (which is only 1000k's old) and plugs, so I know these fluids are fresh. Below is a list of parts and prices I've obtained from a local supplier, I'd like to know if anyone knows where I can get these items cheaper from an online seller. If you know prices, please include the total inc gst and if possible shipping =)
Red Line Gear Box (Lightweight Shock Proof): $138.60 - ~3.7L $36.75 - ~.9L
Red Line Diff Oil (75W-90 the LSD friendly type): $34.70 .9L Someone let me know if they recommend something different/better etc.
Water Wetter (Coolant Additive to increase heat reduction efficiencies): $30.45 - 354ml
Fuchs SuperSyn 5W-40 Engine Oil: 20L - $220 5L: $68.20
NGK's: $114 - BKR6EIX-11 -< I know these can be had for $99 Delivered from a member of these boards.
K & N Filter Recharge Kit: ??? Guessing $120 or something?
Oil Filter: ??? Can't be more than $20?
Cheers for ya help guys. I'm not looking for a debate on what's a better product (unless something I have listed above will cause damage or engine wear etc) but if you have a suggestion then feel free to add it.
https://www.sau.com.au/forums/topic/107554-maintenance-items-best-pricing/
Cool didn't know Nissan had them on hand, though I'm wondering if my local Nissan does... Car is going in there on Friday anyway for a check so will ask them then.
AND IN BREAKING NEWS!!!
My money was returned to my account and has now been transferred to the RIGHT account, 18" Impuls here I come =D
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
