R34 & R33 Parts
Price Drop!!!
I am selling:
R34 RB25DET NEO Coilpacks set of 6 as New (engine had done 7,000km when written off) $300 Sold
R33 RB25DET Coilpacks set of 6 good condition 80,000kms $200
R34 RB25DET NEO Engine wiring loom $300
R34 RB25DET Injectors 386cc set of 6 $250
RB25DET Top mount manifold Stainless NEW $250 On hold
R33 RB25DET Nismo engine mounts NEW $200
CA18DET Top mount stainless manifold NEW $225
S13, S14, S15 Stainless front pipe Replaces cat convertor NEW $200
R33 RB25DET Standard Fuel Injectors and Rail $200
1.JPG R34 Loom
7.JPG R34 Coil Packs
4.JPG R33 Coil Packs + loom
5.JPG R33 injectors + rail
RB%20Manifold.JPG RB Manifold
8.JPG R34 injectors
Edited by fat200sx
Fat200sx...its hard to tell from the pics (although it looks like it has the ignitor plug) but is that a series 2 loom? Ie what year was the skyline made? If it is series 2 consider the sub loom sold!
Oh and how much do you want for it (postage to Perth)?
Trying not to be a pain...but 97 coil packs have the mounting holes in different places to R34 ones (98-2000) they work perfectly fine, but are not physically able to bolt to the head. Didn't cause a problem in my last R34 though, the packs seem to be built better than the later ones.
fat200sx.....it is a bit hard to work out who your comments are directed to from your posts...maybe address the peoples questions by using their usernames.
Anyway I assume when you wrote about the 97 coils that you were referring to my question in regards to the loom. If the coils are from a 97 R33 then they are definitly series 2 and as such I'll buy the sub loom (the wire that feeds the coil packs).
As I only require the highlighted bit in the pic (the sub loom that detaches from the rest of the loom)
how much do you want for it, and I'll need it COD to Perth? PM me or email to [email protected] to discuss $$
Cheers
 Share
    • You guys are amazingly knowledgeable and I appreciate it all so much. I’m currently at the local RB tuning shop, getting her inspected and diagnosed, for the t-case debacle and everything else. I’ll keep you guys posted!
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
