Hey guys, I just got adjustable castor rods the other day and 2 things happend. 1 the steering feels great (a lot better then the old cracked bushes anyways) and also it became a bit more 'sensative; everytime i would go over abump or soemthing, id feel it straight away on the steering wheel. This didnt bother me until i discoverd that afte ri hit about 100 km/h the steering shakes a lot more than it used to with the stock rods. Is this normal? i mean it is a bit of a pain in the ass when ur steering vibrates on the freeway. Also worth noteing is that this doesnt happen all the time, on some surfaces it seems fine. I know its not my rims or tyres cos there pretty much brand new. I also just got a 4 wheel alignment from bob jane.
any advice or reccomendations welcome.
Cheers,
Din.
Hey mate,
The more extra feeling is normal due to the solid linkage rather than the old bushes. I notice it in my Silvia too.
Steering vibrations are usually due to a wheel balance issue. Did you get the wheels balanced when you had the alignment done? If not it is probably worth while or get them to check it again anyway. If you tell them that it is not right at highway speeds they generally just do it again for you.
Cheers,
Adrian
Edited by Adrian Knack
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
