Hi,
I have tried searching on this topic but can't seem to find the answer to my question..
I think I have a faulty AFM or one that is shorting.. Just want someone to confirm this for me..
For example, If I even touch the AFM (like press down on it) the whole engine will rev all over the place (like up and down up and down)...
I have also had issues in the past where I start accelerating and as soon as boost climb's it would cut the fuel flowing to the engine (like boost cut).
Also just driving and not even on boost and the engine was cutting in and out (only ever happened once)...
I'm thinking all these symptom's are relating to the AFM....
Do you think a clean will fix this?
Regards
Ps. I have FMIC, Air filter, Boost (set to 8-9psi not over) & catch can.
https://www.sau.com.au/forums/topic/10760-afm-question/
You have nothing to lose by trying to clean it.
Just take it off, spray either carby cleaner or pod filter cleaner and then wash it off.
let it DRY COMPLETELY.
put it back on and go for a drive.
But from what you are describing, it sounds like it has an electrical issue which might require you to replace it.
Probably set you back about $150 - $200
https://www.sau.com.au/forums/topic/10760-afm-question/#findComment-174380
I have sucessfully repaired my old afm in my car, it would occasionly cut out the engine whalst driving. after replacing it, I decided to see what made the thing tick, stripping it down I found that the connecters on the other side of the connector plug to the circuit board were not soldered properly, hence re-soldering the connections repaired the Afm.
Its easy to do you just need a small soldering iron and some solder, knife and silicon sealent (Sensor Safe).
1 with knife cut away seal of the square top and remove
2 with hot iron in hand de solder copper plate
3 resolder contacts from plug to circuit board
4 resolder copper plate
5 silicon back the square black top back into its place
6 test.
Regards
DAMQIK
https://www.sau.com.au/forums/topic/10760-afm-question/#findComment-174528
mine cost about 360 (for both afm's). from the hpi mag it has more 'tuning resolution'.
'the installation of these meters has given the engine a much greater range of resolution for modification, with the new meters requiring a much greater slug of air to reach full scale voltage deflection. Where 300cfm airflow would normally have the stock meters on their 5.0v maximum output limit, the same flow is only likely to generate some 4.0v through the Z32 items, which gives the tuner much more resolution. This is good for tuning a mild car better and essential for tuning a wild car properly.'
....from the mag.
my stock meters stuffed up on me so i got the Z32's. didnt notice much of a power increase but ratio's held up very well.
to set it up on a pfc-equipped car, just plug in the meters and select the Z32 option on the hand controller, then finalise the tuning from there... too easy :)
https://www.sau.com.au/forums/topic/10760-afm-question/#findComment-175371
  • 4 years later...
hi mine has just started doing this seen alot of threads saying the afm one person has said to me could be the ecu relays could it possibly be that do you know but one of my problems is it seems to be putting more fuel through making the exhiast pop when its winding down also cuts out at random times totally or loss of power at times then it comes back on again ,the pins u resolder are they under the actual board so you would have to take the whole board out or are they just the ones you see when you take the panel off thx
https://www.sau.com.au/forums/topic/10760-afm-question/#findComment-3325925
if you remove your AFM from the car and look at it at this angle...
http://www.skylinegts.co.uk/images/Parts/R32afm.jpg
The very top part is a square cap.
it is sealed by black silicon.
you need to remove that cap and you will see under it, the pins that need to be re-soldered.
to remove the cap, you will need to cut out the silicon.
stanley knife run all the way around the cap in to the silicon should do the trick.
once soldered, put the cap back on and silicon it in there.
you can get the black silicon from bunnings or even the cheapo crazy clarks type places.
it comes in a toothpaste type tube.
it is also used to seal car windows to their frame.
this sort of crap.
http://www.electronicplus.com/images/products/30806.jpg
https://www.sau.com.au/forums/topic/10760-afm-question/#findComment-3328224
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
