Hey Guys,
Not sure if this is normal but ive had my exhaust for nearly 7-9 months now, and ever since i have been getting a strong smell of petrol when i turn the car on or off never while im driving.
I thought it was just the smell of the exhaust, and also use bt ultimate.
I put injector cleaner but made no difference. Inside the cannon the smoke martial (not sure what its called) is very dark. I took a tissue and put it in front of the exhaust while the car was on it went completely black
What does this mean?
Any feed back would be great.
Thanks
Babylon
https://www.sau.com.au/forums/topic/107609-smell-of-petrol/
Check the seal on the side of the fuel tank where the inlet pipe goes in... mine looks brittle and i have dampness (of petrol) around it.. just bought the O ring that replaces it... my smell gets worse when the tank is full, and if i do a hard left..
https://www.sau.com.au/forums/topic/107609-smell-of-petrol/#findComment-1990357
i checked the seal just in case but the smell comes from the exhaust only when i turn off the car or on.
anyways
i think i know what the issue is
i changed petrol brands so far been driving it seems fine
im on Mobile 8000 (98octane)
Edited by Babylon
https://www.sau.com.au/forums/topic/107609-smell-of-petrol/#findComment-2024545
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
