I am moveing and really I dont need all this stuff.
I got the following that needs a home if possible
One of those all in one gyms with arms and legs $350
Boxing bag with frame $250
3 Seater couch + 2 x 1 Seaters $150
Corner computer desk with filing cabinet add on bought from officeworks 3 months ago for $900 asking $250 + I got a leather chair I will throw in.
If anyone needs pics I can supply.
Dan
Look on the office works website under fawkner workstation its a nice piece of stuff just not what I need as it is a little BIG for me now
Got fileing cabinet and extra space to lay your work out, CD rack and underneath storage, dedicated computer spot, pull out keyboard etc
http://www.officeworks.com.au/shop/catalog...D&viewimages=no
OK if nobody wants them they will be picked up by St Vinnys in about 7 days to go to the less fortunate or homeless to do weights etc.
No I am not giveing them away for low prices I just dont have the room and would rather they go somewhere as I dont have the room.
You want to make an offer let me know as I am running out of time.
Dan
What are the lounges like...do you have a pic?
I don't actually need any but if you're desperate i might be able to find someone!
ps. don't give everything away to vinnies, put em in the canberra times tomorrow! I'm sure you'd sell them... better to get some $$ for it than nothing!
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
