Gtr Parts
Hi all,
Located in Brisbane the following parts to go :tongue:
GTR 33 Tanabe Sustec Pro Coil overs height ajustable with helper springs front and rear also comes with adjusting spanner. Perfect Condition, Have put standard stuff back in $700.00
Skyline Blitz 1inch lowered springs front and rear only, slightly lower than standard but much firmer $100
Momo RACE Steering Wheel Perfect conditon with skyline boss kit if you want. $150.00
R33 GTR VSPEC Diff and Pumps includes complete case and lines and centre in very good Condition $400.00
call Adriano on 0412009412 or PM or [email protected]
pick up or buyer to arrange freight payment by direct deposit.
:smile:
What is the diameter of the Momo Race wheel and do u have any pics?
Momo Wheel is 35cm Dia.
hey whats up, whats your best price for the diff center chitch ?
where u located im in melb let me know asap
catch
Hi in Brisbane and thats the best price. THANKS
YOU CAN GET TRANSPORT THRU "PACK AND SEND" IF THAT HELPS
  • 3 weeks later...
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
