Well, I read an article a while back where a guy with a GT4 Celica put the Lexus V8 motor (LS400/SC400)
into it, and it actually ended up being lighter than the 3S-GTE!
Might be an interesting hybrid idea for a skyline. Imagine hearing a skyline go past with that V8 rumble,
you'd confuse everyone! :)
Oh would someone be able to confirm that since I am dropping a RB25DET into the Cefiro that i just need to get the Apexi PFC suited to that engine..ie R33 GTST. Or is it not as simple as that??
Ando
Ando
yep. there is also a group buy on these in the FS section ;)
Konect - Yeah man been PM'ing Greeddy enquiry about whether will work. Just wish I had one of those trees that money grow from.... :P
P.S. Is it just me or is my avatar not working ...*scratches head*
Edited by R33Deviat
you'd confuse everyone! :D
Someone up here in qld actually has an r33 with the 4.5l q45 V8 in it, AND a supercharger :D
With the ae86, someone else up here has one with an rb25 in it, to say the least it hauls. Then there is the 180sx with the 2jz in it, and one big mofo turbo... Then the starlet with the 3sgte in it...
But rb25 is a sensible option. Id just like someone to do the rb30 before me so I know if there is going to be any problems :)
hey mate
yeh i've done the rb30
its all pretty straight forward.
rb30e bottom end
c33 rb25de half cut. because there cheap and non vvt
you can run a standard head gasket (rb30 or rb25)
8.2-1 compression
you need to lower your engine,eith with rx7 engine mounts or cut and shut your current ones(the cross member not the mount.
you need a little re wiring nothing major (not sure on costs sorry also done myself)
cost under a grand as i done all the work myself
still n/a at the moment beatins SS commo's and my mates r34 rb25det NEO(stock)
highly recommended.i'm still totaly stock and very happy with my performance.
hey mate
rb30e bottom end
8.2-1 compression
LoL, awesome man. My mechanic has done quite a number with rb26 heads, so I would probaby go that way.
How was the crossover pipe and the bonnet???
  • 2 months later...
No worries, bonnet wouldnt shut cause of timing belt cover, lowered motor about 20mm, no problems with pipework.
