QLD Raceway Sprint Day April 26
locutus_of_bris
 Share
  • Replies 57
Ok, well it's time to get this moving again. 2 weeks now till the 26th of april and I am heading out again with new tyres and hope to see how they can change the lap times. I would like to do more to the line before then but i cant see it happening (like venting the brakes). All in good time i spose.
anyway, is anyone else interested in coming out to the track that day? Hope to see a few of you out there. :stupid:
Since the last post I have been flooded with replies (actually flodded with silence would be closer to it).
Is anyone even thinking of coming out to the sprint day? If you have never been then I can recommend it. A nice way to have fun and push the limits without risking the new speeding fines (which are gonna hurt)
Anyway, let me know if your heading out and we might be able to cruise on out, or back, or whatever
SVD, you'd pretty much drive past my place on the way out there then if you're at KD... I'm about a block from the bridge that heads into the CBD :D
Might head out for a look but won't be able to race.
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
