HELLO
i have some parts from my skyline left over and need to sell them
Some prices Are neogotible
GFB Mach 1 BOV BLUE Trumpet $150
Ross FLYWHEEL Chromemoly $450
RB26 Grex cam 9.6 lift unsure duration $200
2 1/2 inch Canons Second hand Titanium 3 inch inlet $80 each
Standard GTST Guards Black $300 pair
Standard Front Bumper $100
Standard wing $100
Standard Coils Series 2 $200
Standard Manual Computer $200
standard Throttle body $100
Standard Inlet Plenium $250
Standard fuel Tank $150
Standard Radiator and Clutch fan $200
Standard Air Con PUMP and lines with Radiator $150
VeilSide GTST Front Bar Black $400
Standard Throttle Body $100
GTR Valve Springs $150
GTR VALVE Buckets $150
RB25 Top Intake Pipe $50
RB25 Balancer $100
Rb25 Turbo Inlet Rubber Pipes x2 $40 ea
RB 25 Turbo Dump Pipe $30
RB25 Oil Pump Good Condition $80
Oil Filter Heater $80
CUSTOM INTERCOOLER ONLY SMALL 450x250x65mm $150
Here are some of the photos
Edited by MR331307
if this is the one in the pic with std bov...
also known as aluminium crossover pipe...
$20 with out standard B.O.V
pm sent
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
