HELLO
i have some parts from my skyline left over and need to sell them
Some prices Are neogotible
GFB Mach 1 BOV BLUE Trumpet $150
Ross FLYWHEEL Chromemoly $450
RB26 Grex cam 9.6 lift unsure duration $200
2 1/2 inch Canons Second hand Titanium 3 inch inlet $80 each
Standard GTST Guards Black $300 pair
Standard Front Bumper $100
Standard wing $100
Standard Coils Series 2 $200
Standard Manual Computer $200
standard Throttle body $100
Standard Inlet Plenium $250
Standard fuel Tank $150
Standard Radiator and Clutch fan $200
Standard Air Con PUMP and lines with Radiator $150
VeilSide GTST Front Bar Black $400
Standard Throttle Body $100
GTR Valve Springs $150
GTR VALVE Buckets $150
RB25 Top Intake Pipe $50
RB25 Balancer $100
Rb25 Turbo Inlet Rubber Pipes x2 $40 ea
RB 25 Turbo Dump Pipe $30
RB25 Oil Pump Good Condition $80
Oil Filter Heater $80
CUSTOM INTERCOOLER ONLY SMALL 450x250x65mm $150
Here are some of the photos
Edited by MR331307
if this is the one in the pic with std bov...
also known as aluminium crossover pipe...
$20 with out standard B.O.V
pm sent
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
