Ok here go's i had my RB26 built 19000km ago. It has been running well tell last week.
Coming out of a corner i put my foot down and when i let it off the Throttle it stayed reving so i taped it a couple of times. It stop reving i pulled over car sounded like a WRX so i turned if off. Frist thought coils when i went to check this the car wouldnt start. Took it back to the shop which built the motor and they told me that the comp test was 115,120,90,5,0,80 so thats bad. Anyway what would cause this so quick.the shop blamed the head until i said they rebuilt that too. So anyway what ever is wrong with the car was not their fualt LOL.
so could be???
Fuel pump
Rings
head????
what was done to the engine in rebuild
Block was bored, decked and acid bathed
bullet rods
forged pistons
stock crank with jun collar
kings race bearings
N1 oil and water pump
gates timming belt
head has bronze value guides(exhurst side only maybe)
Anyway thats the basics so what would cause the low comp and how dose it happen so qick
Thanks Brad
https://www.sau.com.au/forums/topic/107683-rb26-need-help/
i bent the exhaust side if No 6 . had 0 comp... cant see it causing a reduction of comp like the other cyclinders
That would be because some of the valves are only slighly bent.
Bent valves - only for drivers who don't like rev limiters... or for dodgy engines with weak valve springs.
https://www.sau.com.au/forums/topic/107683-rb26-need-help/#findComment-1986778
Many things that people can only guess.
You'll have to have it properly looked at for the correct answer
Yer know i just wanted to see what people thought it could be. so had a fair idea how much it was going cost.
Rev limiter was set at 8200 car has stock turbos running 11psi boost tuned by a power fc 251rwkws
https://www.sau.com.au/forums/topic/107683-rb26-need-help/#findComment-1987107
Why don't you mention to them to remove the spark plugs and stick a worm camera in there to have a look, without having to remove the head.
This process have save me ten of thousand of dollars in pulling motor/heads off.
https://www.sau.com.au/forums/topic/107683-rb26-need-help/#findComment-1988075
My guess is that she's gobbled the rear exhaust wheel.........its a brave man that puts ceramics back onto a new engine. :)
Yer brave i think word is dum. I will pull the exhurst off tomorrow and have a look as well as check the oil. i was just at the end of my buget last time.
https://www.sau.com.au/forums/topic/107683-rb26-need-help/#findComment-1991437
  • 1 month later...
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
