Original Steering Wheel - $80
Dashboard w/vents - $60 (has a bubble in the middle) SOLD
- centre vane of the right centre vent cannot control the rest of the vanes
- one minor crack on perimeter of right centre vent
- one vane on left vent cannot be controlled
Odometer plastic surround with light and wiper switch intact - $50
Odometer (128,615Km on it) - $70
Air-con electronic unit(not working for cold air, but ok for the rest of the functions) - $80
Mirror/window control unit - $70
Konis Yellow Shock Absorbers and King Springs- $1100 (incl. new dust covers and bump stops - less than 10,000km old)
Whiteline Front Swaybar - $120 (less than 10,000km old)
Whiteline Rear Sway bar - $120 (less than 10,000km old)
Whiteline Castor Rods set - $100 (less than 10,000km old)
Left front guard - $120
Left front light unit - $100
Left rear light panel - $50
PM me... Resonable offers will not be refused.
:whoops:
https://www.sau.com.au/forums/topic/107696-r32-gtst-parts-4-sale-price-drop/
  • 3 weeks later...
Sorry for the late reply, but I believe that they are 24mm(front) and 22mm(rear).
They are taken off from this website:
http://www.whiteline.com.au/default.asp?page=/yourcar.htm
What size are both swaybars?
Cheers,
Nath
    • Yeah, even here in SA they used to not allow coilovers if they could be adjusted (down) after they'd been inspected and "passed" at Regency, because....you could just drive away and lower it. But now they take the view that they may as well just pass them, and if you lower it below the limit then it's on you when you get defected and they will make your life harder on the subsequent clearance inspection.
    • Just to give an update coilovers passed without any issue!
    • Ducan , yeah sure mate , the unit is https://www.carlinkit.com/ambient TBox Ambient -  plugs straight into the USB C and it runs as a android  unit and you can link your phone to it via Bluetooth , but it only allows for one phone at a time. you can download and apk files you want and load it on there , I downloaded a basic maps apk (OsmAnd+ — Maps & GPS Offline) so I can run navigation without data usage , its not as good at google or wazes but it works fine for what I need. I can put up screen shots if you like. Cheers Pac
    • Hey Team , just got the Fujitsubo unit installed , not a big db difference but it does sound better across the rpm range , I have the front pipe on order I'll post a video with sounds when that has also been installed.
    • The gearbox in my R32 GTS4 (now with RB25DET) has just over 300k on it . Life includes some track time. Has had one change of oil in its lifetime. I rev match on down changes. I don't have any problems with synchros or gear crunching.
