first of all, i'd like to say hello to all of you in the forums, the info here is priceless and has helped me at many times.
i have a 1993 r33 gts-t with the following mods:
front mount cooler, 600 by 300 by 76mm
turbosmart type 3 plumback blowoff valve
turbosmart dual stage boost controller
k and n pod filter with cold air intake hose from bumper
thasts about it for performance mods
im currently running just under 10psi and have tried to go more but the engine pings and splutters and it sounds like the engine cuts out for a second or 2.
i called a guy that specializes in turbos who has a dyno and he said a s-afc would fix those problems along with a dyno tune.
what do u guys think??
and whats the difference between the s-afc and the s-afc 2??
thanx in advance
https://www.sau.com.au/forums/topic/10771-do-i-need-an-apexi-s-afc/
i dont plan to upgrade the turbo anytime soon, or the injectors,
i got quoted $600 for an s-afc, and $700 for a s-afc 2. do they both do the same thing, cos if i dont need to spend the extra money then why bother
whats a ruff price for a piggy back ecu???
and what can it do that a s-afc cant???
thanx
piggy backs usually can also do ignition timing (ala apexi ITC).
rough price for a piggy back ECU? I'll tell you a rough price if you can tell me how long a piece of string is :( (get my drift?)
controlling timing can also gain you a bit more power than just fiddling with air/fuel. the prices you got are about right. consider installation and tuning cost too.
is there any other way to do ignition timing???
cos im pretty sure that ignition timing might be one my problems, i thought that sorta thing can be tuned without anything additional.
one more question, is a piggy back ecu more than a s-afc??
Well the SAFC is actually a piggy back system in that you still retain your standard ECU, it only does air/fuel ratio not timing however the timing is fine set at factory setting of 15 deg. I have similar mods to yours and without the SAFC my car carried on a bit as well mainly due to the over rich A/F ratio, but I was still able to run 11psi. I would go the SAFC II as your best off with the latest stuff although there is nothing wrong with the earlier model.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
