  • Replies 117
Jeeepers.. that's not good..
anyways - yeah what are the KKR's like.. problem is no-one has had them on for probably more than 6months.. what's gonna happen in 2 years?.. is it gonna have an issue or still be going 100%..
could be a case of "you get what you pay for"..
KKR - Otomoto - www.otomoto.com.au
KKK - Blitz
Monsta Everything - All Ebay specials (special as in half of em never last so it a lottery)
There is one "interesting" result here about the KKR-480:
http://forum.r31skylineclub.com/index.php?topic=44524.0
As you'll see i've already alluded to the fact that the dyno figure is "interesting".
300rwkw on stock injectors and a 480hp turbo/15psi
Anyway, take it was you will, ive read no information to lead me to the fact the KKR/Otomoto turbos are ball bearing.
Meaning they are just bush bearing, and no different in performance (which wasnt the best) to sh|tty bush T04's of the years gone by.
Maybe slight wheel changes, but it'll never compare to a Garrett/HKS/Precision etc etc
My personal thoughts on it all:
1) If your getting an Ebay turbo beware, buy at your own risk as they fail often. Just because "someones" works, does not mean yours will. There is no warranty despite what they say
2) They are cheap, and cheap for a reason... to make a quality turbo costs money, so pay the extra 600-900 and get a proper turbo. If one fails, its costs you another 800, then you could have purchased a turbo that would give you car no down time, and better performance
and?
That link provides no spec of the car, not even which turbo is being used, or what motor
No dyno charts to give an indication of response
Can you provide it or something dude? :cheers:
We need more detail before you can say "someone is using it" doesnt say a lot for a technical discussion like this which goes into more depth at times
Hello Scott,
The KKR-480 is $899. We also have a dump pipe available to suit the RB25 for $149 (suits standard or aftermarket front pipes).
To fit it on an RB25 you need to rotate the compressor housing and actuator to point the right way. The actuator rod also needs to be bent and adjusted to suit, while the compressor housing needs around 2mm ground off at one point, where it is too close to the exhaust manifold. You will also need a different bolt for the oil feed and a 2.75-inch V-band clamp. We have a mobile mechanic in Sydney who does the complete installation for $520 including the clamp.
We recently fitted the KKR-480 to an RB24, which made 256kW at the wheels on 1.35bar boost.
Here are some more specifications:
KKR480
T3 twin-port type flange (will suit normal T3 flange also)
Oil-cooled, large turbine housing (around 1.1)
Approx 480hp
Compressor side (similar sizing to smallest HKS GT3037)
Compressor inlet pipe 70mm
Compressor outlet pipe 50mm
Compressor wheel inner diameter 53mm
Compressor wheel outer diameter 76.5mm
12 blades, six 22mm high, six 16mm high
Turbine side
25mm flap-type internal wastegate
71/79mm V-band flange (inner outlet diameter 63.5mm)
Turbine wheel inner diameter 56mm (similar to HKS 2835R)
Turbine wheel outer diameter 73mm (similar to HKS T04R)
10 blades, 28.5mm high at tips
Ben Ellis
OTOMOTO Pty Ltd
45 Mary Pde Rydalmere NSW 2116
Ph. (02) 9898 1655
Fx. (02) 9898 1254
www.otomoto.com.au
On Friday, November 18, 2005, at 09:48 AM, scott andrew wrote:
and yes it is a bush bearing
Dear son of rajab...
Bend the actuator
Shave 2mm off the comp housing
New bolt for the Oil
V-band clamp
And dump to suit
As quoted $520 to install, plus the dump of $149
Suddenly the price is $1586, if you cant DIY
For less than $300 more... bolt on, no worries...
http://www.horsepowerinabox.com/HPIAB2/prod18.htm
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
