  • Replies 117
I am Currently using a KKR 430 turbo that Otomoto have kindly sponsored for my drift car, i took it out for its first test and tune session at the track on tuesday and i am very very happy with the performance and responce of the turbo.
I cam currently making 190 rwkw's with stock ecu, injectors and AFM, the timing has been changed.
i also have a GTR fuel pump, GTR cooler adn thats abouit it.
Whilist this turbo is not a direct bolt up... to make it fit i did the following.
Fitting of the turbo was not that difficult. otomoto can supply a dump pipe to suit that will bolt straight up to your front pipe this is what i got with the turbo and indeed it does bolt up, however i needed a 2.75 inch V band clamp (they are not a bolt type flange but rather a V band) and these are hard to find, so you'd need to go to your local turbo shop and order one in since most places i went yto only had 2.5 or 3 inch.
Grinding was required on the stock manifold and the com housing to make them clear each other, not much needs to be taken away from the comp housing, just a light linish. however theres a protrusion on the stock manifold which has a thread in it for the heat sheld bolt. i ground this away completly and turbo fits no worries then.
you fit the stock RB20 turbo oil return pipe, so no fab needed there, the oil feed line requires some bending but the banjo meets up easy enough. However you need a Metric Course thread Banjo bolt (nissan stock one is Metric Fine thread) this is a $4 part.
Water lines not needed, i just looped the stock ones around each other.
That leaves cooler pipe and intake pipe, the stock intake rubber pipe is a tad smaller then the intake on the compressor housing. You can make it fit by using hot water and forcing it on, but i took the opportunity to get a metal pipe made anyway, this pipe + one simple 90 degree elbow that had a flare on one end to meet up with the compressor outlet was all i needed.
Marky from Exhaust tech made me the pipes i needed for next to nothing, big ups goes to him!
So yeah, fairly simple, its no direct bolt on, but its damn near close enough! And yeah i dunno about turbo life yet bout mine will be pushed to the limits, rest assured, so we'll see how it goes from that! All in all, for the money they are absolutly worth it!
and the videos.....
the 480 is the same turbo as the 430 but with a larger split entry turbine housing.
This suggest that it would be laggier yet have more potential to make bigger hp
I chose the smaller of the two since ive got a competition drift car and responce is more important then bulk hp.
If you want more pics or specs. Contact
Ben Ellis
OTOMOTO Pty Ltd
45 Mary Pde Rydalmere NSW 2116
Ph. (02) 9898 1655
Fx. (02) 9898 1254
www.otomoto.com.au
i wanna see a dyno chart with AFR's and a separate with boost plot aswell if you dont mind :)
as you can see by the link i posted before...
http://forum.r31skylineclub.com/index.php?topic=44524.0
The 1.1 is stupidly laggy... if you take off approx 50rwkw from the graph in all areas (as i stated the result is fudged) then its damn laggy with a peak power of only around 250rwkw... it takes forever to get there.
With a smaller housing... it would need to be back into the .63 i would imagine to give anything close to "stock" turbo performance
Fitting cost me well under 25 bucks in parts :)
and how much time :P
1hour? $70 labour
2 hours? $140 labour
dont forget to include stuff like that as lots of people cant DIY and have to pay workshop rates.
Plus you took your own time to do it aswell :)
im keen to see how it goes in the long run.I got this off the Otomoto website
Around August 2005, Otomoto launched its own performance brand, KKR. This line of turbos and turbo-related performance products began with the KKR 330, 430 and 480 turbos, which offered a level of build quality not seen at this price point before. Sourced from China, Otomoto has hand-picked products from manufacturers specialising in OEM-standard manufacturing, to ensure a high standard of reliability which is backed by an unconditional warranty.
i'd like to see the conditions.
Garrett offer a warranty also, but its highly conditional, and almost impossible to get them to honour it because of that.
I would suspect anywhere else the same would happen.
Its performance, there is no warranty on it
thats dead right, soon as u mention its not a standard application, running more than stock boost they say bad luck.
my mate just bought a brand new gt3540r and thats what the shop told him when he asked about warranty.
cheers
Brad
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
