  • Replies 117
I am Currently using a KKR 430 turbo that Otomoto have kindly sponsored for my drift car, i took it out for its first test and tune session at the track on tuesday and i am very very happy with the performance and responce of the turbo.
I cam currently making 190 rwkw's with stock ecu, injectors and AFM, the timing has been changed.
i also have a GTR fuel pump, GTR cooler adn thats abouit it.
Whilist this turbo is not a direct bolt up... to make it fit i did the following.
Fitting of the turbo was not that difficult. otomoto can supply a dump pipe to suit that will bolt straight up to your front pipe this is what i got with the turbo and indeed it does bolt up, however i needed a 2.75 inch V band clamp (they are not a bolt type flange but rather a V band) and these are hard to find, so you'd need to go to your local turbo shop and order one in since most places i went yto only had 2.5 or 3 inch.
Grinding was required on the stock manifold and the com housing to make them clear each other, not much needs to be taken away from the comp housing, just a light linish. however theres a protrusion on the stock manifold which has a thread in it for the heat sheld bolt. i ground this away completly and turbo fits no worries then.
you fit the stock RB20 turbo oil return pipe, so no fab needed there, the oil feed line requires some bending but the banjo meets up easy enough. However you need a Metric Course thread Banjo bolt (nissan stock one is Metric Fine thread) this is a $4 part.
Water lines not needed, i just looped the stock ones around each other.
That leaves cooler pipe and intake pipe, the stock intake rubber pipe is a tad smaller then the intake on the compressor housing. You can make it fit by using hot water and forcing it on, but i took the opportunity to get a metal pipe made anyway, this pipe + one simple 90 degree elbow that had a flare on one end to meet up with the compressor outlet was all i needed.
Marky from Exhaust tech made me the pipes i needed for next to nothing, big ups goes to him!
So yeah, fairly simple, its no direct bolt on, but its damn near close enough! And yeah i dunno about turbo life yet bout mine will be pushed to the limits, rest assured, so we'll see how it goes from that! All in all, for the money they are absolutly worth it!
and the videos.....
the 480 is the same turbo as the 430 but with a larger split entry turbine housing.
This suggest that it would be laggier yet have more potential to make bigger hp
I chose the smaller of the two since ive got a competition drift car and responce is more important then bulk hp.
If you want more pics or specs. Contact
Ben Ellis
OTOMOTO Pty Ltd
45 Mary Pde Rydalmere NSW 2116
Ph. (02) 9898 1655
Fx. (02) 9898 1254
www.otomoto.com.au
i wanna see a dyno chart with AFR's and a separate with boost plot aswell if you dont mind :)
as you can see by the link i posted before...
http://forum.r31skylineclub.com/index.php?topic=44524.0
The 1.1 is stupidly laggy... if you take off approx 50rwkw from the graph in all areas (as i stated the result is fudged) then its damn laggy with a peak power of only around 250rwkw... it takes forever to get there.
With a smaller housing... it would need to be back into the .63 i would imagine to give anything close to "stock" turbo performance
Fitting cost me well under 25 bucks in parts :)
and how much time :P
1hour? $70 labour
2 hours? $140 labour
dont forget to include stuff like that as lots of people cant DIY and have to pay workshop rates.
Plus you took your own time to do it aswell :)
im keen to see how it goes in the long run.I got this off the Otomoto website
Around August 2005, Otomoto launched its own performance brand, KKR. This line of turbos and turbo-related performance products began with the KKR 330, 430 and 480 turbos, which offered a level of build quality not seen at this price point before. Sourced from China, Otomoto has hand-picked products from manufacturers specialising in OEM-standard manufacturing, to ensure a high standard of reliability which is backed by an unconditional warranty.
i'd like to see the conditions.
Garrett offer a warranty also, but its highly conditional, and almost impossible to get them to honour it because of that.
I would suspect anywhere else the same would happen.
Its performance, there is no warranty on it
thats dead right, soon as u mention its not a standard application, running more than stock boost they say bad luck.
my mate just bought a brand new gt3540r and thats what the shop told him when he asked about warranty.
cheers
Brad
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
