I'll be finishing the Cefiro with the RB25DE + T70 later today so I'll scan that when we're done.
Last reading was 249 rwkw @ 17 psi
Completely STOCK RB25DE with a T70 600hp, 600x300x100 FMIC, GTR Injectors, Z32 AFM, Desno 600 hp Fuel Pump, Remapped R32 GTST ECU, and that's it.
  • Replies 117
Ebay turbos are BAD......have a look at these links
http://www.mx6.com/forums/showthread.php?t=110947
I think the funniest thing about that pic is they had to stamp the word "TURBO" into the housing, just in case you're not sure what it actually is. Like "nah, it's really a turbo! honest! just read the letters!" ;)
Bear in mind that Canberra is comparatively high altitude, so the BP should be lower.
Check your barrometer, i dont think it would ever go to 930. Currently in Canberra its 1023, With cyclone Tracey coming it might get down to 980 at its worst.
  • 1 month later...
Well I just found this thread...
The passage has so far made 303.9rwkws on 16psi (not with stock injectors) but with stock internals and has done 300+ at 3 different dyno locations. As for all the weather men, Canberra is at 93-96BP it is at altitude and is the true reading, (most weather reports measure at sea level) you can see all the summernats dyno sheets are around that reading.
KKR is a little laggy cuz its big, but for bang for the buck its unreal....Nismoid and others are just pissed they spent 5 zero's and have ball park same power.
KKR all the way
Possible 340rwkws at 20psi but also possible boom with stock internals.
A little bit of info is dangerous huh?
G.
whilst your graph certainly proves max power is possible it still doesnt prove much else.
you said yourself its a laggy mofo. average power makes the car quick on the street, not peaky power like the KKR that you've posted.
the info is hardly dangerous nor does it prose a threat to anyone else on this forums that insists on using corret turbochargers for their application
sounds like it would suck on the street (lag city)
Won't debate that, not run a 1/4 yet.. On R31 I never said it was lightning just posted power.
G.
KKR 480 is not big. A GT42 is big, a t04z is big
A KKR is firmly in GT30 (Garrett and HKS) territory which is a medium sized turbo upgrade family.
Same as TD06's and other turbo brands, which looking at results on this forum, dont even come close.
Do you actually have any technical knowledge to share as to why it is so late to deliver power?
Or are you gonna pretend its because its "big" (which has been established, that it isnt)
Im pissed off :) news to me.
Im actually quite amused you can sit here and try and pass it off as a viable upgrade
I had useable power some... 2500rpm earlier. Or maybe 3000rpm.
Its just so hard to tell with your graph as its got the powerband of a turbo double its size
http://image-cache.skylinesaustralia.com/f...-1144976656.jpg
Go run a time then come back and tell us how good it is.
You'll find yourself falling into a hole inbetween gear changes so im predicting a time in the 13-sec zone
Until then, its a paper weight in terms of a performance upgrade without some evidence
Im pissed off :D news to me.
With the modded actuator its boosting from 2800RPM so if you are 3000 under that, then I'm impressed :D
And I told you that you are pissed :nyaanyaa:
PS Why so hostile on KKR did one rape your sister or skyline :laugh:
With the modded actuator its boosting from 2800RPM so if you are 3000 under that, then I'm impressed :(
And I told you that you are pissed :(
PS Why so hostile on KKR did one rape your sister or skyline :D
If it starts building @2800 and takes what... 3000rpm to build to 20psi...
I dunno how else to term un-responsive
Yep 2800 with the big boot at 5000rpm (on 16psi)
In the process of gettin some hoops for the strip I'll see how we go.
G.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
