Some facts on KKR, to help reduce some of the confusion.
Yes they are a plain bearing or 'bush' type turbo. A lot of people put too much weight on this specification, when really the way the turbo performs on the engine is what matters and there are clearly plenty of users who are happy with the results.
They come with a 6-month unlimited replacement warranty, which is the best warranty offered by any turbo manufacturer to our knowledge.
They are not the same as the many 'ebay turbos' that have been mentioned. These are manufactured by a company which builds turbos for various European OEM customers, using all German machines.
They are not a direct bolt-on for any particular engine, but the work required to fit a KKR430 or KKR480 to an RB20 or RB25 is not very complicated and the whole job can be done in half a day. It is true that with a dump pipe and installation the KKR480 will cost $1500-1600, but compare this to most other options and you will find it is still extremely cheap. Remember fitting any turbo, including a 'bolt-on kit' will cost a few hundred in labour.
As for power output, we have seen many RB25s making 240-260kW at the wheels with a KKR480 and 16-18psi boost. We have also seen the odd unusual example making close to 300kW, but given the manufacturer rating of 480hp, mid-200s are a realistic expectation.
We have yet to see any KKR430 turbos used in a high boost application, but with 12-14psi we have seen 180-215kW at the wheels on RB20 and RB25 applications. The smaller exhaust housing and turbine make it less suitable for high-boost applications, but it is very efficient at moderate boost levels.
On an RB25 a KKR480 will deliver full boost at around 4000-4500rpm, depending on tuning, cam timing etc. A KKR430 will deliver full boost by 3500rpm, but both turbos begin to produce boost from much lower rpm.
Ultimately the results will vary a lot depending on tuning and the other parts fitted to the car, but keeping in mind the price, the KKR turbos are hard to beat on a dollar-per-horsepower ratio.
Anyone wanting more information should refer to www.otomoto.com.au or email sales@otomoto.com.au
  • Replies 117
Judging by that dyno graph, it shows that positive boost (around 3psi) is made ~3300rpm and full boost is achieved at ~5000 rpm? Is it just me or does that seem a little late?
Ben, on your own website
Tested by Croydon Racing Developments on an RB25DET Neo engine, it produced 242kW at the wheels at 18psi.
297rwkw is 55rwkw more, with 3psi less boost.
On a motor that has a 1.8mm head gasket, i find that also to be quite interesting.
Upto 20rwkw variance i could believe... 55rwkw variance my mind tells me isnt correct.
Also, would you be able to shed some light as to how a stock RB25... which means 370cc injectors to the best of my knowledge... can make 297rwkw?
There is no mention of a massive fuel rail pressure increase that im aware of, being its a stock motor.
Im very interested to know the above as are many others im sure
Best to call Jake's Performance for info on the tuning of this particular car. It did have a huge fuel pressure increase as far as we know. As for the later spooling, again this relates to tuning, cam timing, compression ratio etc.
Abit off topic: my r33 made 290rwkw on standard injectors. this was with massive fuel pressure increase and 044 pump. tuned by matty spry in se qld. most se qld people will know who he is. My comment is to support the fact that 360+rwhp can be made on stock injectors but they will be at there limits. Several qld cars have made over 400rwhp on stock injectors and ran into the mid 120mph range down the 1/4. I would say they should take that car down the track to show its potentail.
have a quick looksy at
http://www.skylinesaustralia.com/forums/in...e=post&id=25136
if you wanna see how this turbo combo compares against some other rb25 turbo setup.s
With a lower BP reading is shows a higher RWKW figure as its in shootout mode. My friend has a dyno shop and his dyno read around 98BP when it was 101BP. I kept on getting high figures approx 10% higher. Went back to the shop when it was fixed and he showed me how it all works ala, now true RWKW not inflated. I'd hate to think of the true lower RWKW of a 93BP reading.
Bear in mind that Canberra is comparatively high altitude, so the BP should be lower.
From my perswonal experience there is one particlar e-bay turbo that is BAD - The '50 70' as some call it... This is the turbo on the MX6 link, and has nerouse bad reviews everywhere.
I have fitted the T70 to serveral cars now with excellent results, and seem to fine for long term also with the first that I fitted 8 months ago still going strong. They are rated at 600 so expected to be laggy.
I have also tuned 2 CA1DET's with the KKR 330 and KKR 430, the 430 was fairly laggy on the CA, but the 330 gave me the biggest shock! 206 rwkw @ 16 psi with awesome response.... I am completely confident the 430 would be an excellent turbo on a larger capacity (2lt or 2.5lt) motor.
Summary:
EBay - '50 70' = BAD
EBay - 'T70' = Good
KKR - =Good
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
