I'll be finishing the Cefiro with the RB25DE + T70 later today so I'll scan that when we're done.
Last reading was 249 rwkw @ 17 psi
Completely STOCK RB25DE with a T70 600hp, 600x300x100 FMIC, GTR Injectors, Z32 AFM, Desno 600 hp Fuel Pump, Remapped R32 GTST ECU, and that's it.
  • Replies 117
Ebay turbos are BAD......have a look at these links
http://www.mx6.com/forums/showthread.php?t=110947
I think the funniest thing about that pic is they had to stamp the word "TURBO" into the housing, just in case you're not sure what it actually is. Like "nah, it's really a turbo! honest! just read the letters!" ;)
Bear in mind that Canberra is comparatively high altitude, so the BP should be lower.
Check your barrometer, i dont think it would ever go to 930. Currently in Canberra its 1023, With cyclone Tracey coming it might get down to 980 at its worst.
  • 1 month later...
Well I just found this thread...
The passage has so far made 303.9rwkws on 16psi (not with stock injectors) but with stock internals and has done 300+ at 3 different dyno locations. As for all the weather men, Canberra is at 93-96BP it is at altitude and is the true reading, (most weather reports measure at sea level) you can see all the summernats dyno sheets are around that reading.
KKR is a little laggy cuz its big, but for bang for the buck its unreal....Nismoid and others are just pissed they spent 5 zero's and have ball park same power.
KKR all the way
Possible 340rwkws at 20psi but also possible boom with stock internals.
A little bit of info is dangerous huh?
G.
whilst your graph certainly proves max power is possible it still doesnt prove much else.
you said yourself its a laggy mofo. average power makes the car quick on the street, not peaky power like the KKR that you've posted.
the info is hardly dangerous nor does it prose a threat to anyone else on this forums that insists on using corret turbochargers for their application
sounds like it would suck on the street (lag city)
Won't debate that, not run a 1/4 yet.. On R31 I never said it was lightning just posted power.
G.
KKR 480 is not big. A GT42 is big, a t04z is big
A KKR is firmly in GT30 (Garrett and HKS) territory which is a medium sized turbo upgrade family.
Same as TD06's and other turbo brands, which looking at results on this forum, dont even come close.
Do you actually have any technical knowledge to share as to why it is so late to deliver power?
Or are you gonna pretend its because its "big" (which has been established, that it isnt)
Im pissed off :) news to me.
Im actually quite amused you can sit here and try and pass it off as a viable upgrade
I had useable power some... 2500rpm earlier. Or maybe 3000rpm.
Its just so hard to tell with your graph as its got the powerband of a turbo double its size
http://image-cache.skylinesaustralia.com/f...-1144976656.jpg
Go run a time then come back and tell us how good it is.
You'll find yourself falling into a hole inbetween gear changes so im predicting a time in the 13-sec zone
Until then, its a paper weight in terms of a performance upgrade without some evidence
Im pissed off :D news to me.
With the modded actuator its boosting from 2800RPM so if you are 3000 under that, then I'm impressed :D
And I told you that you are pissed :nyaanyaa:
PS Why so hostile on KKR did one rape your sister or skyline :laugh:
With the modded actuator its boosting from 2800RPM so if you are 3000 under that, then I'm impressed :(
And I told you that you are pissed :(
PS Why so hostile on KKR did one rape your sister or skyline :D
If it starts building @2800 and takes what... 3000rpm to build to 20psi...
I dunno how else to term un-responsive
Yep 2800 with the big boot at 5000rpm (on 16psi)
In the process of gettin some hoops for the strip I'll see how we go.
G.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
