Am really pissed off i just intalled a to4z hks turbo on my R33 gtr, However i had problems with my standards air flow meters so im looking for z32 air flow meter and they air so hard 2 find can anyone Help me and tell me where can i find them in Brisbane and what price range am looking at ....!!!!
cheers
https://www.sau.com.au/forums/topic/107719-z32-air-flow-meter/
You can buy them new from your local repco automotive parts place
but be prepared to pay mega bucks for them.
or you can them through greenline.jp or nengun.com
or look in the for sale section
or even possibly group buy (was one recently)
Petroject mate or i think they are called Automotive Service Solutions now.
Ph: 1300 30 40 60 if that aint right check the yellow or white pages online.
bosch z32 afm i think this is the part no# for it F00E000202 the bosch number.
Cheers mate.
  R31Nismoid said:
Get em new - nengun or greenline
will take 1-2 weeks to arrive.
Or you can get Nismo AFM's... same as a Z32, will bolt into original spot too.
more like 4 weeks once you've placed the order, then they confirm, then you confirm, then you make payment, then they confirm the payment then they order it then they send it...about 4 weeks
1-2 weeks is after they confirm your payment
cheapest i've seen brand new is from nengun for 400...but can you wait 4 weeks?
http://www.skylinesaustralia.com/forums/in...howtopic=107544 :O
Edited by kbear_s15
http://www.skylinesaustralia.com/forums/in...howtopic=107544 :)
yours might have taken 4 weeks
stuff i have ordered, 1 week.
cheers
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
