ewww.. vespas are not sporty or fast!!!! :O
sif alien knows anything!
But he told me you two used to be a hot ticket item
(Then again, i get the impression hes never touched a female before)
So whaddaya say Mona, good times? I promise I wont take photos, or if I do you can have a cut of the proceeds once i load them on my website
Edited by R33
  • Replies 268
Popular Days
yeah... but it means i'm a nagging annoying female and norhing more, ms!
quote dammit!! i had to go back to the other page and re-read what i wrote to find out what u were on about ....
are u sure there is nothing else?
sif quote!!
nothing else!
and i think r33 is someone we know using their old account!
hahaha... richard.. who cares if the movie sux! as long as the guys are hot! :O
Typical women, only watching movies to perv on the men.
We arent chunks of meat you know Moanie, we have feelings
yeah he's a dream boat...
Sugoi
sif quote!!
nothing else!
sifnt quote and i reckon there is..........
i was just about to say that.... currys only watch movies that have their favourite actor/actress in the movie.. they dont care about the story.. ;o
:O i actually find it amusing hanging around with guys all the time... a hot chick walks past... and convo stops... jaws drop... lol!! priceless!!!
hahaha.. i do!! :tongue:
see!! i quoted :ohmy:
Garbage, name one guy here that would eye off a hot girl that happened to walk past.
damn i just wasted 20c sms ing you thomas. word is i just enrolled in japanese class at Syd Uni. paid my money and everything.
hahaha why is it a waste ??/
you bastard....I thought you enrolled before me !!! and was waiting on me !!
I was broke that week and I scrapped the cash together so I wouldnt miss out !! :tongue:
Anyways when do you wanna get our books then ???
Im going in tommorrow to buy some Hyper Rev mags amongst other things....might see if I can find the books we need.
Guest
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
