Ok this morning i had my car tested for faults, coz its been playing causing it to idle ( drops ), misfire! anyways had it test and it came out AFM ( faulty).. does that cause the car to behave when its faulty? liek what are the symptoms?.. and thats what it was showing on the tester? is there way of cleaning this? if so how do i actually clean this? is iut worth it cleaning it or just buy a new one?? or should i worry that there will be other problems? i had second hand coils put in! they looked mint? new sparks plugs? clean the injectors and put in a new fuel filter?
cheers - Mike :O
Edited by 33tech
https://www.sau.com.au/forums/topic/107740-afm-help/
They can be cleaned with carby clean but from my experience if they are just dirty they don't read as a fault.
I opened mine up by cutting around the outside of the sealant that seals the top panel then prying it out.
You'll see a metal sheild under the cover. Unsolder it and remove it.
The problem with mine was where the pins from the circuit board were soldered to the pins in the plug socket the solder had cracked.
I heated each joint with the tip of my iron and added a small amount of solder.
I resoldered every joint on the back of the board just to be 100% sure but I doubt this was necessary.
Solder the sheild back in place and reseal the cover panel back in place with sikaflex or silicon.
This fixed my missing, stalling and unsteady idle problems
Good luck.
https://www.sau.com.au/forums/topic/107740-afm-help/#findComment-1994594
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
