Selling these rims, need to free up shed space
Tyres good for drift, 2 ok for road use,
Rims are 17x8 front 17x9 rear, with all wheel nuts
Asking $500, with a pair of pretty well had it RE55S Semi Slicks chucked in as well (one needs puncture repair)
Spray 'em black, white, whatever! Would be a great set of track/drift wheels
https://www.sau.com.au/forums/topic/107758-drifttrack-rims-for-sale/
hi do the rims have any flat spots or bad chunks missing from the edges looks like they have some gutter rash have u got a closeup of the worst damage
what is the offset please I like these sparcos my car had them in 18s but wrong offset I am keen for these if the offset is suitable and the damage is repairable.
Hi,
the two rears have a bit of scraping, mainly from using semi-slicks as they have no rim protector.
Offset is 38 I think, I will have to check.
Do you have GTR or GTSt? Don't think they would be suitable for GTR, I believe you have to keep rim sizes the same front and back other wise you stuff up the workings of the 4WD
Will post up offsets when I find out what they are.
If this gives you any indication, the rears just fit inside the rear guards, same with the fronts
Will post up them up when I find out
Chris
Chris
Hi Chris Still waiting for the offsets are the wheels still for sale?
will transfer the $$ to your account today if you are selling.
Hey mate,
I had a look on the weekend, couldn't find much on there. From memory there was a sticker saying they where 32 or 38, can't quite remember, but it looks like it has come of when they where on the car
Is there any other way I can measure the offset on them?
^^^Offset is distance from centre of rim to the surface/flange of the rim that bolts onto the hub. (sorry can't explain better)
So the higher (+'ve offset) figure will mean the rim sits more inside the guard, and for lower or -'ve offsets opposite applies.
So a rim width of 8" (200mm), halfway/centre will be 100mm, likewise centre of 9" (225mm) rim will be 112.5mm.
Measure the distance (mm) from outside edge of the wheel towards centre (width wise), ie edge of rim to the surface of the rim that will bolt onto the hub, now subtract this distance from either 100mm (for 8" rim) or from 112.5mm (for 9" rim) and this should give you your offset.
Alternatively, measuring from the "inside" edge of rim to the same surface as above where hub bolts on, then subtract either 100mm (8" rim) or 112.5mm (9" rim) from that distance and it should be the same value as the first method.
Best way I can explain it.
Hey mate,
theres an easy way to measure the offset
get a straight edge at least 20'' long [a brickies level is perfect] lay it across the rim at the back and measure the distance to the back of the mounting flange then lay it across the front of the rim and measure the distance to the back of the mounting flange, the difference between the 2 measurements is the offset, you can get a close enough measurement even if the tyres are mounted and the straight edge lays on the tyrepost-23827-1141631231.jpg
