  • Replies 297
Posted Images
I have gone for the covers etc to be fully polished up for a nice clean look with some brackets powder coated blue where others are powdercoated black..Still have a hard pipe to fit this weekend which should brighten it up even more..Engine will then get a once over to clean the dirty fingerprints and then i will get some proper pics of the engine and car..
Heres mine with paint just mixed up at autobarn with the heat stuff clear,
anyone got any sugguestion on how to get the rest of the shit off the plenumpost-16324-1167909787.jpg
and markyboy.1967 ur engine bay looks good lots of works gone in to it
and btw i like ur idea on cutting the middle bit out for the coils never seen it b4
sorry to bother you but what are your filters? they look almost the same as what I am chasing to replace the m's filters on my car.
James.
thought id pop these up , i thought id go for something completely different , i was gonna go get something done in the shop, but i thought id do this myself , and have 2 colours to make it stand out... looks crazy , im happy with the way it turned out.
alright guys for those who want to know what was done . ill do a mini write up in this thread !
1/ pretty much if you search the forums for "rocker cover diy" you will find a great write up on how to remove them and replace the gaskets. now you dont need to replace the gaskets unless they are cracked . i planned on replacing mine because i had an oil leak along the bottom block . but the gaskets looked fine and were still rubbery . my guess is the screws werent tight enough even though they shouldnt be too tight !!
when you remove your CAS , gauge with a marking knife exactly the position around the bolts onto the CAS so you dont distrupt your timing .
2/ once you have removed everything and you basically have your coil cover / rocker covers and cam cover off place them on a surface. collect a can of degreaser . spray all these items down thoroughly . wash the degreaser off after 2-3 mins . now there still maybe a rough surface and build up of debree. so collect some 800 gritt wet and dry paper . wet each item as you do them and sand them down until they are 100% smooth and free from any dirt . on the coil cover also remove the nissan 2500 sticker or tape it up . along the sides of the coil cover it could apear cracker , this is a small thin like a gasket to make the coil cover sit hard in , mine was cracked heaps , so i just removed it - it comes of heaps easy , and just clean any debree with a stanly knife.
3/ once everything has dried , collect some thinners or turps/metho . and wipe down to clean any missed debree. thinners would be the best because it'll eat it away and dry off fast .
4/collect the engine enamel paint of your desire. now lightly do 1 coat with smooth strokes. repeat this process 3 times so you have 4 nice tough coats , and leave about 20 mins between each coat or until touch dry. leave to dry overnight. the supercheap paint is primer enriched , so you dont need to buy a seperate primer.
5/ the next morning . check for any debree that could fall on the parts , if so lightly sand them off and maybe spray a final coat . if not needed , collect the can of clear enamel , and do a nice thick coat , so that its all nice and glossy. do about 2-3 coats allow 1 hr drying between each . the clear enamel takes a lot longer to dry.
6/ you may need to leave everything for a couple of days . because the clear may take a while to harden , as said in on the can , the items wont fully be cured until under emense heat . so basically when they are on and installed again they will dry over time , and the heat will help dramatically.
7/ if you have light oil leak like i did , i also got some sealent for the gaskets from supercheap auto and placed it all on the bottom block where the gasket sits , to seal everything.
8/ collect all your bolts and spray them with degreaser before you install - so they are nice and clean , i found this usefull because mine were all dirty and im in the process of cleaning my bay out thoroughly.
9/ be carefull when installing everything , i had a few knocks and a few scratches . its not easy doing it by yourself so all i can say is be carefull because it could happen , and use something to prop up any cables/hoses to prevent light scratches . if you do get some , the spray is good because you can do little touch ups and it will dry as its been a full coat spray .
10 / once installed make sure your car starts properly etc . and everything is connected before starting.
my products used were from super cheap .
i used the following
- septone - yellow engine enamel - 2 cans , you will only need 1 and a quater can , will have heaps left over for future touch ups if needed. [ around $15 a can]
- septone - clear high protectant engine enamel . - 1 can only [ $18 ]
- 1 sheet 800 wett and dry [ $1 ]
- 1 can degresser [ $2 ]
- small amount of thinners / metho / turps [ $4 ]
- gasktet sealant [ $8 ]
thats pretty much all i can say for now , but if you have any further Q's , just PM me . or let me know if iv missed anything . thanks for the comments guys . cheers
Edited by sky017
i did one rocker cover before on another car - and in all honesty , the paint will only crack if you dont remove all oil from the covers , happened to me on my old car , small section cracked , i found moisture in between cracks , must of missed a spot when cleaning .
so be carefull and take your time dude . and cover all your pipes with cloth too , i dropped a spanner down my fmic pipe ha ha lol - had to take the lower pipe off - mistakes happen so take mine to your advantage .
good luck - cheers
haha im on to you - i picked one up this morning from bunnings and started doing my crossover pipe . didnt finish it because i needed to drive . if you look at the crossover compared to other side you will see the colour difference. i need to buy a smaller one to reach into crevices .
yeah, I saw your partial buffing. I've got a tip for you bud. You have to get it flat before you buff it.
Start by using a file, or a sanding attachment for a grinder. Get rid of those dimply things.
there used to be a great thread on supra forums, but the link has changed
I love the clean and shiny/painted engine bays. The only thing making me scared to do it is the stupid cops. I'd hate to be pulled over, and the cop sees shiny bling bling, and decides to defect me.
Whereas, if it's stock looking, he might just look over it and ignore it.
yeah man i only used steal brush on the end of my drill to test it out . but im gonna do that properly in a couple of days .
btw why would a cop defect you for have a shiney engine bay? unless you have a visable atmo bov and some other things , then your asking for trouble.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
