  • Replies 297
Posted Images
^^ nice engine bay.. wot silver did u use and did u clean/sand the pipes before painting??
Paint stripped all parts, then gave it a light rubb with 320
Spayed them with 3 coats of edge primer, this gave it enough build to remove all grains and edge primer is very easy to rub.
Spray a quick guide coat to sand it back with 800
Applied about 4 coats of silver, then 4 coats of the candy purple (the more coats the darker it gets) and then 4 coats of clear.
My mate owns Xclusive Colours in Smithville so access to this stuff was easy :dry:
The silver used is corse silver mixed with the new Mazda white pearls
The purple I will keep a secret, might be using it on other things. But there's alot of colours and pearls in there to create that colour.
Black CAS looks awesome Sean in that bay!
if your keen one day - come around and i'll "chrome" coat that lower outlet pipe - should get it close to matching the twin turbo pipe.
Hey yea when i did my rebuild i saw a really nice gold on these rims and i got the guy to do my covers for me but having seen the purple one on the previous page i am regretting not doing it a custom color shiz!!!!!
I dont mind mine atm no one really does them gold anymore Golden heart for my baby!!! but im having some serious problems with dressing my engine bay up if anyone has some ideas for me plz post its so depressing i want my engine bay to come to life wen i pop the hood i wan colors bit of chrome not so much dullness!
952328092008828.jpgImage Hosting
_K1NGTR_
start with the little things - remove and polish the throttle linkages
paint teh CAS
little bits and pieces til you get to the point of having to tear it all down to get the Plenum and twin turbbo pipes etc etc
BUT!~!!!!!
think of a theme and stick to it .. needs to all work together
yea thanx for that man the cars getting resprayed atm so i should pull little things off here n there. any idea where i can get the chrome pipes from the turbo that everyone seems to have?
you have to take them to get chromed :P or polished
and to replace those big black pipes with alloy ones usually means an aftermarket intercooler kit.
yea yea thats what i meant the after market intercooler kit and like the piping to the air flow meters i want to make them metal but i will get there eventually..........i hope lol
  • 1 month later...
After reading this thread and looking at some good results I decided to do my RB25. I used Holts MetalCast Anodised Blue, which has some mixed reviews. However I have found the reuslts to be fantastic.
I started with a good prep of sanding with 400grit then 1200 on both rocker covers, cam cover and the exhaust manafold shield. Used a lot of degreaser to make sure the surfaces was right. With the sanding I was back to bare metal in man cases however its hard to get all the little spots. Overall this took about 30min per piece.
I started then with the Hoyts MetalCoat primer, which by itself actually looks pretty good. I did a number of coats within 10min until the items looked perfect. Then I commenced with the color. Overall I did approx 5 coats with 10min of each over with th elast coat being quite heavy. Once they are left to cure, the anodised color really comes up, each bit looks really good however my camera could pic up the shine.
Once its been left for about 1 week I will start with a high temp clear to bring up even more gloss and protection.
Some of the pics from yesterday after I left them to sit overnight, bit of dust already on them! The gloss doesnt show up in the pics, but I can assure you its there in a big way. Need to learn how to use my new SLR!
post-27030-1225755109_thumb.jpg post-27030-1225755121_thumb.jpg post-27030-1225755126_thumb.jpg
^^ good work, i tried doing exactly the same with my parts but found the spray nozzle would dribble at time instead of spraying correctly, ruined the paint with blotches.. doesnt look like u had that problem though.. it does look great when shown in the sun..
hi mate, yeah I read about that but I had no such trouble, you have to press it in pretty hard and contanstly shake the bottle...once you get to the end of the can it can become inconsistant. It doesnt take long to sand back and give it another go..I redid parts of the cambelt cover and it now looks even better.
Just deciding what color to paint the coilpack cover, prep and base coat done already.
I got the cam covers, front pully cover and plenum powerder coated satin black with a slight wrinkle.
I'm thinking about getting the alloy intake pipe to plenum and air intake pipe to turbo done the same.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
