looks good though, those flat (shinier) spots would prob be from not enough paint on them, even coating is the key. nice start!
did you put them in a warm place (sun) once you caoted to help with the wrinkling effect, have seen a few "how to's" for this paint and this has been common requirement
yeah the even coating is a bitch, i let them settle for a couple hours then threw them in a oven for a hour at 100c
ended up repainting the flat spots, then coating the whole lot with darker red caliper paint, looks good, not great
  • Replies 297
Posted Images
Hey just a quickie, would it be cool if i used paint stripper to remove the standard black colour that comes on the covers? I've been sanding it for hours and am only just getting to the alloy and thats just on the cam belt covers, it's going to take forever at this rate
rb25 or 26?
25's are steel and you need them painted
26's respond well to paint stripper, comes off really easily and is a semi polished finish underneath.
that smoothness is the main reason for the coatings failure, no priming is done over a smooth surface.
Ah cheers, they're rb26, i'm planning on respraying them anyway (in kh2) just was worried the paint stripper would react badly to something and i'd have some wrecked or unpaintable covers on my hands
Shame your not in melbourne i'd just take the easy way and send em your way :thumbsup:
its usually under $50 return shipping along the east coast from my experience with other customers mailing them up and back, not sure i could get an exact match to the gun grey metallic but i could find something close.
depends on who's painting them and what your being charged really as to whether its an option for you :thumbsup:
depends on who's painting them and what your being charged really as to whether its an option for you :D
Ah, yeh true might look at doing that, can i get a quote for the prep/spray (pm if u prefer)? I know theres like 4 or 5 different KH2 shades from nissan so something that looked close or even slightly lighter would probably look fine
im gonna giv my covers a go on monday
im gona use duplicolour metalcast get along with the groundcoat undercoat...hav ppl experianced fading of the red due to the heat?
yep i did Sl!m's covers ages ago, it went orange after a few months
ok so i went out and bought the dupli-colour ground coat and duplicolour anodized red, preped the cam/timing belt cover and rocker cover ie. degreaser, wet n dry, etc
applied the ground coat, (3-coats) turned out beautiful, nice even coverage...and metalic too hehe
anywayz, started to apply the red, first light coat, second light coat, then third abit thiker, turned out darked in some area and some areas abit lights, waited then applied another even coat, made the top half of the cam covers and timing cover realy realy dark....realy disapointed, left a matt finish...for 3 cans and $60 later, im pissed off, and not puttin them bak on like that, gona giv em a rub bak, go to a panel beating supply shop down the road and see wot he suggests and just do it with the spray gun
spewing !! :blink:
they wernt that hard to get off realy, just take off ur pipe where the blow off valve is, intercooler pipe is u got an aftermarket cooler, un-do the timing belt cover and crank angle sensor, then just unscrew the valley cover and cam covers, it realy is that easy, today was the first time i took them off and took me about 20mins....
thanks mate, gona giv it a go tomorow
  • 2 months later...
Heres my work in progress, Metalcast Red with Chrome and Grey (whats the actual colour Chris??) powdercoating by Craved Coatings.
Ill post up more when its finished this week. I reckon the fuel rail turned out awsome :(
post-31195-1244538722_thumb.jpg post-31195-1244538765_thumb.jpg post-31195-1244538907_thumb.jpg post-31195-1244538961_thumb.jpg post-31195-1244539057_thumb.jpg post-31195-1244539130_thumb.jpg post-31195-1244539194_thumb.jpg
  • 1 month later...
  • 1 month later...
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
