  • Replies 297
Posted Images
Can anyone tell me, isn’t 2pack what most normal OEM paint is? I want to paint my cam covers in a color that comes on a Subaru, but don’t know if it would take the heat of the engine bay? Does a hardener or special type of clear coat need to be used?
Any help would be appreciated
- M
Anybody had experiences with VHT Wrinkle Plus?
Seen some pics with that on a holden rocker cover and it looks pretty schmick.
They came like that from the factory. :)
GeeTR, when painting engine parts, the main consideration is how much heat the items will be exposed to.
If you use clear coat on something which is exposed to prolonged heat, the clear coat can become discoloured (yellowish-brown) and may start to bubble/flake/peel.
My engines:
When I started painting parts in the engine bay of my first 31, there wasn't much of a range in hi-temp paint colours, and I learned the hard way that there can be a fair bit of colour variation in the hi-temp paints.
I used "Lively Lavender", and over the span of the project I used 2 different cans of paint, which is quite visible in photos.
If you need to paint lots of stuff, or need to do a few coats to get the colour you require, I'd recommend using one can for the first layer/s and a different can for the final colour, so that any colour variation in the finished product doesn't stick out like dogs nuts.
The back half of the rocker cover and the engine lifting loop things (one at rear, one in front) are visibly darker.
Fortunately there's a much bigger range of colours (and textures) available now. :happy:
The new project is getting more sedate colours used on it, so I've gone with Ford "Blaze Blue".
The blue is not hi-temp, just regular duco paint.
It's not as "WHOA!" as the lavender, but it still looks pretty.
(I really should take some more pics, this photo was taken in full sun and the colour looks very washed out)
The part showing at the back is more representative of the actual colour.
There was no primer used in either of these projects, just good preparation of the surfaces prior to painting.
All paint has held up fine, no discolouration, no peeling.
If you use clear coat on something which is exposed to prolonged heat, the clear coat can become discolored (yellowish-brown) and may start to bubble/flake/peel.
Yup, that’s what i figured, hence i asked if any one had experience using normal 2pack paint on cam covers, and issues with heat around the exhaust side.
People color match body to other parts all the time, cam covers, inlets, what ever, i was wondering if its literally the SAME paint as used on the outside body, or if they are mixing something with it to make it more robust.. or using a different clear
Cheers all
i'm getting mine done for my 32 done @ the moment and if i hadn't done some of the prep work it would have cost me 300 instead it will be about half that the color is in BA blood orange and thats in 2pak and i'm looking @ going with the same color for my 32 aswell!!
Here's a pic of the duplicolor red > cam covers, apexi pod adapters, and a few other bits. Also did the OEM strut brace - no more faded red (yay). nice chrome strut brace would be nicer but hey - gotta work with what you've got.
Just the coil pack cover to come and then I'll bolt it back on. knowing me I will scratch the sh!t out of them putting it back on and have to start again >_<
Cheers,
Tay
did you use a primer under the metal cast gray base coat?
nope - but i degreased, sanded and prepsoled before applying the base coat.
just make sure you apply an even coat (sufficently thick) of the undercoat as any dark areas (i.e. where you can see some black showing through) will be obvious when you apply the colour.
cheers
the front cam cover i am going to prime anyway, too many scratches on it, was just doubel checking as alot of these engine components actually are textured and i want them smooth.
thanks again
  • 3 weeks later...
hi all well im looking at painting my engine covers to tidy up the engine bay a bit,
jus t no sur e what colour/colours?
so far ive only come up with the ford xr purple as i really like this colour..
my gtr is gunmetal grey so what yous think? also could people post pics of there bays so i could get a few ideas
cheers kane
I just got the rocker covers and cross over pipe polished and the plastic strip sprayed blue. Just wanna know how u guys reckon i should put the nissan badge back on? double sided tape was what it had but thats the good tape from the factory, the double sided tape i got is piss weak.... glue maybe? or the tape will be enough?
how much this cost you
i did my engine bay in purple pearl and all engine covers in ford blueprint blue. the engine goes in this weekend so ill upload pics of it complete, but heres some pics of the engine bay and engine by themselves.
It was $225 for the cross over pipe, both rocker covers and the top intercooler pipe. $25 for the intercooler pipe so i thought i may aswell get the whole lot done so it was all polished the same even though the intercooler pipe was already chrome but it brightened it up a bit.
heres pics of my bay just been sprayed last week nearly finished piecing it back together it's a orange base with a orange metalic and green pearl looks really cool in the son with the whole car changing color in the next few months just need to save for the bodykit going with an origin kit.
trying to figure out what colour to paint mine...
I reckon R34 purple would be nice, but like millenium jade too...
also, does anyone have the part numbers for hte cam cover seals for RB26? the ones on my set are crapped out and have silicon all over them...
Thanks!
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
