Location: Car is TAS registered but is in Melbourne at the moment
Reason for Selling: Just moved to melbourne a couple of months ago and would like the money to spend on things for my house.
Price and Payment Conditions: $26500 firm
As stated the car is registered in tassie, therefore has no RWC. Shouldn't be a problem getting one. Rego runs out in july.
CAR
1993 Nissan Skyline R33 GTS-t M spec
ENGINE MODS
RB25DET
APEXi AVC-R
APEXi Power FC and Hand Controller
ACL Forged Pistons
Blitz FMIC
Bosch 044 Fuel Pump
DRFT Oil Catch tank
Shotpenned rods
Greddy Turbo Timer
Greddy Heavy Duty Timing belt
Greddy Intake Plenum
Greddy Radiator Cap
Brass button clutch, sprung center
ACL Head Gasket
Nismo Fuel Regulator
Nismo 740cc Injectors
Splitfire Super Direct Di ignition system
Tomei Adjustable cam Pulleys
Tomei Pon Cam Shafts
Tomei Valve Springs
Z32 Air Flow Meter
Tomei HICAS lock
Trust AirNX Pod Filter
Trust T76 Turbo
External Wastegate
3” Kakimoto Racing Exhaust
EXTERIOR MODS
18" x 8" MKW Crome Rims
Lowered Bilstien Suspension
GTR Rear Wing
Veilside Body kit
Carbon Fibre Bonnet
Tinted Windows
Nismo Clear side Indicators
Carbon Fibre GTR wing blade
Carbon Fibre Ganador Super Mirrors
INTERIOR MODS
Nismo 300 kph Dash
Aftermarket Gear knob
7 inch LCD Screen (Has a ps2 in currently but am not selling with the car)
Greddy Boost Gauge
Momo Millenium Steering Wheel
Greddy Oil Pressure Guage
Greddy Piller Panel
STEREO
Alpine 1.5 DIN CDA-7897
Alpine MRV-F307 4 channel Amp
Alpine MRV-M200 Monoblock Amp
Alpine Type R Splits in the front
Rockford Coax's in the rear
Alpine 10” Type R Sub
Stinger Platinum Battery Terminals (+ & - )
Stinger Fused Distribution Block 4ga to 2 x 8ga
Stinger Distribution Block 4 x 8ga to 1 x 4ga For grounding
Stinger Helix Series Wiring throughout.
Countless hours and $ have been spent on this car. All engine modifications(full rebuild) were done only 3 months ago (have done approx 6000kms). Engine all up cost me over $20g.
Couple of minor problems ( just being honest) , turbo needs new seals, front bar has a couple of cracks(nothing major). All easy to fix.
The car has been on display at Auotsalon Final battle 2005, Semi-final 2004 and auto show off in mid 2005.
Looking for a quick sale, buyer will not be dissapointed. No test pilots. Any checks welcome.
https://www.sau.com.au/forums/topic/107804-heavily-modified-r33-gts-t-fs/
