**MADAZ RX8**...well guys heres my new chop...been to long in the making...bout time i finished the big girll....yer so an absolulte shitload done to it....pretty much everything that can be done....targa top roll cage...arches kit so on....so yer just let me know what u think i think this is my best chop yet!!!! cheers guys!...
ORIG: rx80oc.jpg
Thanks guys.
https://www.sau.com.au/forums/topic/107805-madaz-rx8/
  • 2 months later...
that is the work of a genius ... almost as good as my sig :)
when i saw this thread i thought u were talking to me since that is my orriginal gaming name :P
i droped the Rx8 bit for this forum :D
** edit **
if u dont mind i will use that as my next sig pic sumhow and i will leave the created by ur name in it sumwhere
Edited by Madaz
https://www.sau.com.au/forums/topic/107805-madaz-rx8/#findComment-2201642
i swear ive seen that before.. but i could be wrong :)
but i def know ive seen that S15 in your sig before... are you on any chop forums? PSU?
:P
also very nice chop only thing i dont like *besides the fact thats its a RX8 lol* is the spoiler besides that
the chop is awesome. great work with the reflections :(
https://www.sau.com.au/forums/topic/107805-madaz-rx8/#findComment-2242211
  • 2 months later...
  • 3 weeks later...
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
    • I don’t mean this in any negative way. But, if u are after this type of data why don’t u have a flex fuel sensor?
