Would some one please shed a little light on the following.
I would like to know wether a 4" exhaust is going to flow that much more than a 3.5" .
Will it make a lot of differance on a high hp ( 900 ) engine.
What size do most of the high HP GTR run ?
I would like to be able to work out the flow rate some how.
https://www.sau.com.au/forums/topic/107807-exhaust-size/
i would imagine it would make a massive difference.
the less backpresure on the turbine housing the better usually
i think the racepace rb30 gtr has a 4" dump into a twin 3" system. it was in one of the magazines, speed im pretty sure
i guess the ideal way to find it would be to run it on the dyno with the exhaust attached then do another run with it deattached and see the difference, may highlight if its a restriction or not
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1988775
4" ? Crikey, how do you go with tucking that up the belly of the car? If you need the exhaust flow, then surely its easier to package twins on the underside of the car rather then a biog single???
Good point Roy!
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1989151
No it won't make much difference, 3.25" is the tested optimum max size with a GT3040 turbo, so 3.5" should be enough. Sorry I can't remember who tested it.
edit - argh still getting used to the controls of the new forum, lost most of my typing...here goes again.
I like that dual exhaust set up, you should be able to make the car quieter while also getting even better flow characteristics setting it up so that the exhaust tips are smaller but still meet the 3.5" total size. Multiple smaller exhaust tips should create a lower pressure differential and assist flow.
I like this idea, so now I wonder where I can get dual exhaust system from in Sydney? Is there a brand name option for this or is it all custom?
The noise on my car is perfect lower tone (same tone all through rev range, just volume change) but a bit loud on low throttle ie. off boost,
I'm thinking of installing an exhaust valve controller (EVC).
Should I get tuner to set it with the computer to automatically open and close proportionate to the THROTTLE or BOOST or RPM ???
(Anyone have advice on whats best?).
Edited by Edge
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1989184
Umm, sorry to say but a GT30 is only around the 300rwkw mark.
This is hardly what is being asked here.
What was asked was a 900HP setup, well over 500rwkw
So the above statement has nothing to do with this thread.
Bigger is always better. I cant see how 3.25 was "optimum" as the less backpressure the better. 3.25 would have been the minimum requirement
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1989296
Apexi make a dual cat back system.
Ive got a custom catback -2x2.5" pipes to 2x 3" mufflers. It works out to about the same as a 3 and 3/4" single pipe.
It is quieter, and doesnt drone.
A 3" should be good to 300rwkw, a 3.5" to 350+ but over that id want to flow at least a 4" (or split 3") system.
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1990277
Not speaking from any experience here from owning a hi hp car,but,i have been swapping from stock to aftermarket exhausts of late and the power difference is very noticeable.
Even when there is just a silencer in the end of the sporty it takes away all of the fun in owning a sports zorst.because there is that initial surge of power for a split second and then it's like it just returns back to normal power levels.
Id personally go for the biggest zorst u can fit.Especially if you are using it mainly for track duties.:P
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1990872
what size did you have for your 369rwkw run ash?
Oh, and for the RB26, im going twin 2.75" (or there abouts) off the GT-SS/trust split dumps, aiming for 300-320rwkw.
As Bl4cK32 said... you can get it quieter and less drone... hence why im now going twin... noise is only good for so long
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1990968
All intertesting in put fellas , but would like to see / hear of some solid evidence of flow characterisics,eg what volume at X pressure will y Dia flow etc?
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1991813
Bigger isnt always better, its just better than smaller. Going to big adds weight. Fact is in Australia, we chuck 3" on everything from 600hp GTRs or XR6s to 200hp CA18s. It works but for example, the CA18 could make exactly the same power as with a 2.5" exhaust unless youre chasing more than 450hp at the engine. Even most street WRXs are fine with 2.5" exhausts and make no more power with 3" exhausts. All this is within reason and notice I said "most" and "street". Exceptions always exist.
http://www.turbomagazine.com/tech/0212tur_exhaust/
Turbos operate best with no exhaust backpressure (Quote Bell's book) so you can see where the fact bigger is better comes in, but remember there will be a point at which bigger is going to yield no more flow and just add more weight.
Also, surface area is no good for comparison, you need to use pipe volume with respects to resistance, pressure etc which is a fluid dynamics formula. Quite simple really, so dont stress. Look it up on the net >_<
Boosted frog
https://www.sau.com.au/forums/topic/107807-exhaust-size/#findComment-1995545
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
