Howdy guys!
In light of my car not going anywhere fast due to dead engine, I am going to hopefully tackle a few DIY jobs this weekend. :huh:
I am planning on putting in the coilovers, doing the 5 stud hub conversion and fitting some 5 stud rims.
Now really never done this before and was wondering if people who have done it before could give me a few times.
Coilovers ______
1. Is it a case of removing the current suspension and bolting up the coilovers? Does any modification need doing?
2. Also a mate mentioned some kind of tool is required when removing the stock spring to stop it taking ur head off??? Is a standard G-Clamp gonna go the trick with a bit of improv? :laugh:
5 Stud Hub Comversion ______
1. Pull the standard hubs off and bolt on the new ones? That simple?
2. Is there specifics i need to be aware of?
Rim Fitting
1. Pretty sure just bolt em on and take it to the nearest tyre place for alignment / balance?
So any help / advice / tips would be so so greatly appreciated!!
Ando
https://www.sau.com.au/forums/topic/107883-suspension-help/
OMFG Konect!!! If u didnt live in Melb I'd but you a beer or 2 or 3 or even a 6 pack!!!
Found the linky. Awesome write up on how to do it! HHMmmm time to punish the work printer!! PRINT PRINT PRINT!! :laugh:
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1990202
Found the linky. Awesome write up on how to do it! HHMmmm time to punish the work printer!! PRINT PRINT PRINT!! :(
LOL work printers / photocopiers are also good for printing multi-page cruise maps :P
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1990664
Coilovers are easy peasy.........just remove the whole existing coilover from the car and replace with the after market unit u have. (funny how it is so much easy to say that! eheheheheh) ......it is very straight forward ....it just some bolts can be a bastard to get off. If you need any help just let me know ....im just a few stations north of chatswood.
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1991528
strut swap should take no longer than an hour by yourself with a jack, 18mm, 17mm and 14mm
fronts - jack car up by crossmember or 1 side at a time via towhooks with axle stands - both wheels must be off the ground of the swaybar will be lopsided which is where a long 2m pole for leverage to pry it comes in handy (if both wheels off the ground this wont need to be done)
losen top 3 bolts either side strut towers
undo bottom bolts and remove (nut should be an 18mm and bolt a 17mm or other way around)
undo top bolts completely and pull strut out
repeat process backwards to install new struts/overcoils
rears: jack car up by diff so both wheels off the ground
losen top bolts 2x each strut tower
undo bottom 17mm bolt and remove
push shaft loop off of lower control arm
undo top bolts complete and remove strut
repeat process in reverse to install new struts/overcoils
only part youll need someone for is to do up the top bolts on the rears losely when reinstalling... and possibley depending on how wound down the overcoils are - someone to lift the lower arm assemblies to slide inserts for front and rears into position to bolt at the bottom
enjoy!
Edited by Hella Flush
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1991767
sky80 - Ha come around to where....
Resin.. Mate i know the North side like the back of my hand. I live in Chatty area and car is usually either around there or up north around Hornsby.... Will de doing the work around that area.....but if i have any issues maybe PM me ur mobile #?? If u want....but by the sounds of it should be sweet....
More worried about the 5 stub hub conversion... that will be fun....
Ando
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1991850
Okay well time to report in after the weekend spent under the car.....
Coilovers went in easy as pie! So much easier than expected. Case of Carlton Draught, a mate with every tool under the shed and she was done in a couple of hours!! :)
Things i have noted -
1. NFI on how to set the Softness / Harness properly. On the rears it was pretty easy, just turned it till it wouldnt go any 'softer', then made 15 clicks on both sides to harden it up. The fronts are a diff issues. Unlike the rear coilovers, it would not come to an 'end' when clicking it to the softess setting...it just kept clicking along.... so was unable to get a 'starting' point :P So just clicked both sides +20 clicks of hardness to each side and hoped for the best. Seems to be working fine thou, NO MORE SCRUBBING....woot!!
2. Handling has changed significantly! The ride is so different.... i think i have set it TOO hard as when accelerating it 'skips' along if the road is a little bumping like it is trying to keep rubber to road. I think it will take a bit of trial and error here.
3. The rear is sitting WAY TOO LOW!! The front guards are sitting about 2-3 cms above the tyre whereas the rear guards are sitting about an INCH below the tyre :blush:. I know how to adjust the ride height but i did it up as much as possible on the rears and she still sits on the deck.... I am thinking i need a spring clamp to try and compress the spring to try and wind up the nut a bit more..... Put it this way, the standard jack only just fits under.... the exhaust rides about an inch off the ground.....SCRAPIE SCRAPIE!!!! But should be something a little tinkering cant fix
4. WTF on the front coilovers are the four little adjustable bolts on the top for? They can be moved left to right with little line markings on em....didnt touch this as i didnt wanna fcuk anything up
I also planned on doing the 5 stud hub conversion this weekend but yeah hit a few snags and ended up not doing it. Reasons -
1. The rotor discs need to be redrilled to fit the 5 stud hub thru.....FCUK THAT!!!! :laugh:
2. Too hard basket!!!! :huh:
So plan now is to try and source the full R33 brake, caliper, hub, rotor etc so to do the full conversion. Or source so decent 17" 4 stud rims....whhic as we all know is next to impossible!
Apart from that fixed the power steering but i think i need a new pump big time as she 'whines' so much when turning the wheels!
NFI on where the wires are for the horn. Got 1 and was struggling to locate the right wires.... Will be posting piccies once loaded so ask u guys if any ideas. I know they are supposed to sit right behing the front bar but there was only 2 wires free and they didnt seem to work.....
So yeah all good apart from a few issues....
Just need to save $$$$ for a new engine as it is getting rediculous driving around with white smoke belowing out of her! :)
Ando signing out!!
PS thats Alex for the offer! May take u up on it very shortly. Payment by beer of course lol
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1996987
yea getting the height right can be a little bit of a pain ....just make sure u measure everything .....so both sides end up the same height. Also are the hardness might be caused by the springs being too hard......mine were (well too hard for me) so i have swapped 6k rears into front and im getting some new 4k ones for the rear.
Not sure about the front shock adjustment why it doesnt stop. unless its broken. ( are they second hand?)
Also are urs base adjustable? as well as under spring adjustable?
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1997628
Resin - Mate did a rough measurement of all corners and had them pretty much same for fronts & rears.
I have NFI what KG rating the springs are.... :D All i know is the fronts are fine but the rears are questionable!
They are new coilovers, well display model, so who knows....maybe i didnt click enough times but hey how many settings can there be.....
Base adjustable / Spring adjustable...WHA DA??
There is the 'needle' adjuster on top for hard / soft with 4 little bolts on fronts at top by the struts...as before NFI what these 4 bolts do....
There are 3 adjustable nuts under the spring. One at the base where it connects to the wheel / hub. 1 right underneath spring and 1 below to tighten the top one......
That is as far as i know that provides adjustability....once again having never dealth with coilovers before i am very noobish :laugh:
Ando
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1997685
Ando
4 little bolts sound like the screws for the camber adjustment. ....
the 3 other nuts sound like the locking plates? ............if so then the two top ones are used to raise the height of the car ......the bottom one sounds like the locking nut for the base adjustment for the heght (which doesnt affect the spring )......u should be able to undo this and wind it down ..........
upload a pic of them ........will be much easier to explain ! heheheh
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1997806
Resin - Mate sounds like ur on the money :O I am pretty sure the 4 little bolts are for camber adjustment, but once again, have no idea how to adjust this so am leaving as is.
The 3 locking plates are exactly how u described.....just with the rears i have done the top 2 plates up as tight as possible but she still sits so so low...thats why i am thinking about using a spring clamp to compress the spring and try and do em up a bit more!
Took a couple of pics but will get some more soon.
On side note was wondering if someone can help me find where the hell the wiring for the horn is!! Please see 3 pics.
1. Some wire, red / black / grey with a black plastic connector on end
2. Some dooby thingy cylinder with a thread on end
3. Where i assume the wires can be found....behind front bar
Cheers,
https://www.sau.com.au/forums/topic/107883-suspension-help/#findComment-1998074
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
