For those who dont know and care
Microsoft products do not reflect Australian daylight saving time changes for the year 2006
http://support.microsoft.com/kb/909915
:P
Dont Really Know Where To Post?
How about not in every forum? :(
Only the forums for the states it affects.
Up untill this post i have never been into any other states.
I did not even know we had an ACT forum, thats how much attention i pay :P
FYI even though it doesn't affect the other states, if you patch the ones affected by daylight savings.. and the other states aren't patched.. meeting requests and scheudling will be still out.
Dont think so.
Systems that use these products in the affected states of Australia will not correctly reflect the new transition from daylight saving time on April 2, 2006. This problem will cause the time to be one hour off from the correct time on the affected systems.
Daylight saving time for 2006
For the year 2006 only, the official daylight saving time transition dates for each state in Australia are as follows. State name Original date New date
Victoria 26/03/2006 2/4/2006
ACT 26/03/2006 2/4/2006
NSW 26/03/2006 2/4/2006
Tasmania 26/03/2006 2/4/2006
South Australia 26/03/2006 2/4/2006
Note Clocks are advanced at 2 A.M. by one hour on the start day to become Summer Time. Clocks are wound back at 3 A.M. by one hour on the end day to become Standard Time.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
