its been 3 weeks and im missing it like crazy, once this is over it off to adavn so some major engine work
power fc
trust intercooler
550cc injecters
fuel pressure reg.
fuel pump
trust inlet
air filter kit
cold air box
trust turbo td05-18g
boost control
how much power do you think it will make..........
https://www.sau.com.au/forums/topic/107961-paniting-and-engine-build/
nope the injectors should be fine, if your running an updated pump like a 040 or 044..
the AFM will max out and cause some reduction in tuning abilities...
never look at the trust range of turbos so dunno about the TD05... but the injectors would be fine up over 300rwkw with a good pump and rising rate FPR.
yeh injector will be fine, i had sard 550cc with a malpasi and that made 352rwkw (maxed out) id say anywhere up to 240rwkw
ben...
ARRGGHH that means i'll have to upgrade my injectors with the RB30 :)
anyway, back on topic
