Hi
I'm after the driver's side reverse light. This is the little white one besides the number plate. If you still have this how much? I'm located in the northern suburbs of Melbourne so I can probally pick it up. If not I'm happy to pay for Australian post as it's a pretty small item.
  • Replies 107
How much for the speedo cable?
Its the one that runs from the gearbox to the back of the dash.
Postage to Adelaide....
$50 delivered
Will you sell the rims as sets of 2? Will they be sold with tyres? How much?
Only teh white pair left and they do come with tires but not roadwrthy, $180
I am interested in the brake master cylinder if the car DOES NOT have ABS.
If this is the case drop me a PM and I'll come pull it out myself and give you some cash.
Thanks
Hen
Yeh still have it and i don't have abs, just call after 4pm to let me know when you want to pick it up.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
