i just got a autometer air/fuel ratio gauge ...
just wondering on how hard it is to install one of these and would any auto elec be able to do this or only specialised turbo workshops ?? thanks
i wanna get it done this saturday , if anyone could recommend any places in sydney would help thanks
https://www.sau.com.au/forums/topic/10801-installing-airfuel-ratio-gauge/
I did mine with a bit of help from ppl on this forum - do a search and you should find more info. The hardest bit is to find the O2 sensor's signal wire - you either need accurate ECU wiring diagram or top quality digital multimeter - look for the fluctuating voltages...... Anways, do a search !!
Cheers,
Guest nismogtsx
ok... easier... never put the wire on out in the engine bay... cause it will deteriate... plus there is voltage drop inbetween the O2 sensor and the ECU....
Do what i did... Goto the Apexi web page and go to the turbo timer manual.... in there it has a printable diagram of which pin on the ECU the O2 voltage input is... then just splice that wire and solder on.... As the apexi TT has an Air/Fuel ratio function...
Trust me... you want to be reading what the ECU is reading not what the O2 sensor is actually putting out.... For tuning purpose's
