I had my R33 Gtr Dyno tuned at 310 AWKW recently and found out had detonated piston so had rebuild with Forged pistons, head work, metal head gasket, N1 oil pump, N1 bearings, new belts, new crank and blue printing. Had car re tuned and found only 2KW increase in power.
Is this normal? I would have thought it would have increased around 20 kw but still happy with overall power just thought this was interesting. I guess that power just safer with stronger engine now.
https://www.sau.com.au/forums/topic/108019-surprised/
maybe the headwork took you backwards and the extra power from increased compression and the rest brought it back upto your previous power? its abit strange, though ive heard of people not making any extra power from doing a fresh rebuild.
Generally if your engine is in piss poor condition, after a full rebuild it should run alot better, make better power with less inefficiency due to everyting being returned to factory spec or better.
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1992048
Did you lower compression ? What kind of head work did you do? Is the engine still very new and very tight ? Piston to bore clearances? Do a comp and leakdown test then you will see whats going on . The dynos can make a lot of difference even if you used the same dyno .
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1993301
Forged pistons won't increase power.. just your capacity to do so...
yeah but i think he means the car was dynoed with a busted piston and with new ones (not leaking pressure) it should probably produce better power. Plus with the engine cleaned up like new you'd think you'd get a little bit.
Was it the same dyno??
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1994264
Sorry can't say much. It was at same dyno and engine build all arranged through UPI in moorabbin. I know they sent it off to get done and because of christmas break only get the car next week. Sorry don't know much technical terms yet am learning form reading in here though. Thanks for all replies. Car only had 34K on clock and maybe they are genuine as no difference in power after re-build. If so obviosly very happy with car. Get R33 GTR with probaly now 40K in newish mods, very low K's for little more than mods would have cost. Also only charged fo rparts in re-build as upgraded parts involved, just wish had the money at time to do cams and rods. Maybe a future thing and get T04Z or similiar in a few years time.
I read on here that 400+rwkw is the new 300.
Edited by gdogzgtr
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1994743
Ah my bad :) , true it should have made a bit more power over the busted piston... Not a lot tho..
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1995054
Hang on... metal head gasket should decrease compression, right? Thus giving you more potential to boost it higher.
Headwork... if you had it shaved down to increase compression, then you're right back where you started in terms of manifold volume. (due to the metal headgasket increasing the volume)
If you didn't have the head shaved, then it's still the same, and whether you did port matching and so on or not... if the head wasn't maxed out in terms of flow, then porting and polishing shouldn't actually do anything.
You've got a stronger top-end, which should put up with the power you have. I'd be happy with that!
https://www.sau.com.au/forums/topic/108019-surprised/#findComment-1995516
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
