  • Replies 40
press far left pedal to the floor with left foot.
using left hand, put little knob in front of stereo, between your seat and passenger seat in to 1st gear.
apply a little bit of pressing on the far right pedal with right foot, and increase this pressure while releasing the far left pedal slowly..
DON"T BE ALARMED!!!!
Car will start forward momentum.
when the big hand on the dash reaches about 30km, change gears in to 2nd as described above for 1st gear.
now let go of the far left pedal, and stick far right pedal to floor.
keep eye on the road and take small glimpse at this pictured turbo gauge above.
when car is making lots of noise and big hand on dash reaches about 70km, take foot off far right pedal and put it lightly on centre pedal.
while you were taking small glimpses at the turbo gauge you should have taken notice of what the red stick got to..
once you have done this, post back on here and tell us what marker the red stick got to.
we can then tell you how much boost your engine is eating.
any questions?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993304
Unfortunately, I don't have a far left pedal. Gosh it must be missing ;-) I forgot to mention, but mine's a auto/tiptronic model.
Anyway, so what formula do I apply to provided I get red stick reading at an instance of speed?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993323
any questions?
ROFL
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993346
Johnny,
If I knew, I wouldn't be asking.
Given you know, perhaps you could tell me the conversions I am asking for. My boost guage reads in kg/cm2 and mm/Hg. Which is what? And what do they mean.
Edited by sarnil
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993355
OH! Now I get what you mean! Your question wasn't clear.
You want the conversion rate from your boost gauge's readout to psi???
This website converts any pressure reading to various other units of pressure measurement. Go nuts!
http://www.convert-me.com/en/convert/pressure
Hope I could be of help. Sorry for my earlier criticism, but the way you phrased the question suggested you didn't know how to look at a gauge, not interpret what your looking at!
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993371
I guess what I was really looking for was for someone to volunteer to explain to me why my boost guage is setup as it is. I understand that anything over the 0 mark is what would be boosting at, but what about the numbers below the zero? Why do they have different scale?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993410
1.0 Bar = 14.5 psi.
you have 20 little lines on your gauge from 0 - 1.0
therefore each little line on your gauge is 0.05 bar.
which is equal to 0.725psi.
go for a spin, plant your right foot and see what it gets to at say about 4500-5000rpm.
WARNING: lack of far left pedal can cause boredom to the driver and piss taking of them, by their mates.... or people on intraweb forums..
any other questions?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993424
Because when your engine is running at idle, the turbo is not building any boost yet. That's why it goes below 0. Once it gets to 0, it means that all of your intercooler and inlet pipes are pressured and your turbo is ready to make boost.
A good way to test this is to go out for a drive, and in 2nd gear, get the boost gauge to read around the 0 mark. Then flatten your foot and it should increase quickly.
Then try it again at negative boost (e.g. less than 0) and it will take some time for the boost to wind up. Thats the difference. All those pipes that carry boost need to be pressurised before you can gain any power.
Which is also why cars running 4" intercooler piping and giant turbos and intercooler get really bad lag. That 'lag' is all of those pipes filling up with pressure before power can be made.
Hope I helped.
Adrian.
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993437
OK. Will do the read for between 4500-5000 as recommended. Will post the results no doubt.
The decision to have my Skyline even without the left pedal and extra two doors was a long, hard and an agonising one, I assure you. In the end, the wifey won and I still got to have a skyline. I guess it's still better then any other alternatives, don't you reckon?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993449
I'd probably say drive your car for a while, and see how high you boost gauge goes?
1 bar = 14.7 psi
I thought you were after a reading of the boost gauge, hence my posting that 1 bar = 14.7 psi..
I have the same boost gauge.. But as for the different scale below 0 compared to above 0.. I have no idea why they're in different units?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993469
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
