  • Replies 40
press far left pedal to the floor with left foot.
using left hand, put little knob in front of stereo, between your seat and passenger seat in to 1st gear.
apply a little bit of pressing on the far right pedal with right foot, and increase this pressure while releasing the far left pedal slowly..
DON"T BE ALARMED!!!!
Car will start forward momentum.
when the big hand on the dash reaches about 30km, change gears in to 2nd as described above for 1st gear.
now let go of the far left pedal, and stick far right pedal to floor.
keep eye on the road and take small glimpse at this pictured turbo gauge above.
when car is making lots of noise and big hand on dash reaches about 70km, take foot off far right pedal and put it lightly on centre pedal.
while you were taking small glimpses at the turbo gauge you should have taken notice of what the red stick got to..
once you have done this, post back on here and tell us what marker the red stick got to.
we can then tell you how much boost your engine is eating.
any questions?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993304
Unfortunately, I don't have a far left pedal. Gosh it must be missing ;-) I forgot to mention, but mine's a auto/tiptronic model.
Anyway, so what formula do I apply to provided I get red stick reading at an instance of speed?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993323
any questions?
ROFL
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993346
Johnny,
If I knew, I wouldn't be asking.
Given you know, perhaps you could tell me the conversions I am asking for. My boost guage reads in kg/cm2 and mm/Hg. Which is what? And what do they mean.
Edited by sarnil
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993355
OH! Now I get what you mean! Your question wasn't clear.
You want the conversion rate from your boost gauge's readout to psi???
This website converts any pressure reading to various other units of pressure measurement. Go nuts!
http://www.convert-me.com/en/convert/pressure
Hope I could be of help. Sorry for my earlier criticism, but the way you phrased the question suggested you didn't know how to look at a gauge, not interpret what your looking at!
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993371
I guess what I was really looking for was for someone to volunteer to explain to me why my boost guage is setup as it is. I understand that anything over the 0 mark is what would be boosting at, but what about the numbers below the zero? Why do they have different scale?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993410
1.0 Bar = 14.5 psi.
you have 20 little lines on your gauge from 0 - 1.0
therefore each little line on your gauge is 0.05 bar.
which is equal to 0.725psi.
go for a spin, plant your right foot and see what it gets to at say about 4500-5000rpm.
WARNING: lack of far left pedal can cause boredom to the driver and piss taking of them, by their mates.... or people on intraweb forums..
any other questions?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993424
Because when your engine is running at idle, the turbo is not building any boost yet. That's why it goes below 0. Once it gets to 0, it means that all of your intercooler and inlet pipes are pressured and your turbo is ready to make boost.
A good way to test this is to go out for a drive, and in 2nd gear, get the boost gauge to read around the 0 mark. Then flatten your foot and it should increase quickly.
Then try it again at negative boost (e.g. less than 0) and it will take some time for the boost to wind up. Thats the difference. All those pipes that carry boost need to be pressurised before you can gain any power.
Which is also why cars running 4" intercooler piping and giant turbos and intercooler get really bad lag. That 'lag' is all of those pipes filling up with pressure before power can be made.
Hope I helped.
Adrian.
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993437
OK. Will do the read for between 4500-5000 as recommended. Will post the results no doubt.
The decision to have my Skyline even without the left pedal and extra two doors was a long, hard and an agonising one, I assure you. In the end, the wifey won and I still got to have a skyline. I guess it's still better then any other alternatives, don't you reckon?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993449
I'd probably say drive your car for a while, and see how high you boost gauge goes?
1 bar = 14.7 psi
I thought you were after a reading of the boost gauge, hence my posting that 1 bar = 14.7 psi..
I have the same boost gauge.. But as for the different scale below 0 compared to above 0.. I have no idea why they're in different units?
https://www.sau.com.au/forums/topic/108062-boost/#findComment-1993469
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
