meh... he done it again... stood us up!
"i assumed cause we had no 34 it was off"
you know the saying!!
oh well... wasnt a total loss..
thank u to Dave (Leewah) and Ulis... (Ula32) for SHOWING UP.... (damn munkeh!!!)
one bad thing was.... the pics for the card ie. the panaramic shots i took didnt come out very well.... mainly cause of the lack of a tripod *cough*damn ula*/cough* :)
but i did get some nice wallpapers :D
will host em... gimmie a minute.
https://www.sau.com.au/forums/topic/10807-damn-munkey/
I think you need to angle the cars a bit more and have them angled towards the bridge, and sort of cascaded..
also, lower your iso... and up the exposure a little.. its still too dark.
need a tripod :)
also, the panoramic shots wont come out well at all.. if your using a high exposure, even with or without a tripod your still going to get blur, the shutter speed is too slow for panoramic.
https://www.sau.com.au/forums/topic/10807-damn-munkey/#findComment-175554
Was this a cruise/meet or something? :)
I would've come out for a bit (depending on what time... idn't finish work tilll 9.30)
I'd be up... I've got an R31 GTS-R, the boys at Ice have seen it.
Not bad for what it is... and what i paid :D
If you do meet another time... let me know dudes
I might not be able to come all the time but i will try :)
https://www.sau.com.au/forums/topic/10807-damn-munkey/#findComment-175601
ex. i did a panoramic at the last one with a long shutter speed and they came out fine... no blur because it merely takes a normal picture then stitches them together.
i only set the shutter for about 5 seconds... was going to take more with diff settings but it rained... so as stated will have to have another go to do it properly with more time. munky can do it this time sometime earlier than midnight as ppl dont seem to like the darkness.... seems a bit ghey having it light as the stove tops dont stand out as much.
https://www.sau.com.au/forums/topic/10807-damn-munkey/#findComment-175887
hey guys ive just had a brainstorm.......that doesnt come to often.
how about u guys go for a run along that bridge/rd thingy that has all those red archs....i think its after balte headdin towards the airport....does anyone know what im talkin about...hehe...and like fill up all 3-4 lanes with the liners and get someone to take a pic in a car behind em......i recon that would look SWEET!!! and that bridge thingy is kind of a melb landmark.
https://www.sau.com.au/forums/topic/10807-damn-munkey/#findComment-176288
i thoguht youse would have been glad i wasn't there since I don't really do much to start with :)
hehe you def need to lower the iso and up the exposure time, nark trust, i tested them ixus's man, they jus dun have the necessary exposure times we need. What you need is a Canon G1 or G2 or G3 sumfin like that its not an SLR but its a kickyoasswithmahfoot digital that lets u control all the parameters...
another thing nark that pic you made is only 72 dpi roughly eqivalent to about a printout that will come out to be 1/4th that size. The LOWEST print quality you can use is 300dpi means your image needs to be 1020 by 660 pixels MINIMUM to make a decent quality printout.
And you left out the most important part... I TURNED UP when you guys called me and told me, only to see youse take off on me, i said hi and the next thing i see was 3 cars takin off... thought u'se were goin to a new location or sumfin, and when i got to the top of the road i figured that you were goin home.
Anyways, I'll work on gettin a G2 or sumfin of that sort for a proper shoot, or even an SLR. The time of day is good and the fact that we have a street lamp is good too coz it maps out the contours, now all you need is to get the xposure right. Maybe we should attempt a sunset pic, see how that looks.
https://www.sau.com.au/forums/topic/10807-damn-munkey/#findComment-177901
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
